3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Climbing Halloween Skeletons
Step 3I did the same with each foot and leg.
I missed the photo of this next step some how but, hopefully, I can describe it:
Each leg thread goes into the hip section at the hip joint, and out through the spine joint. Then it gets threaded up through the chest area.
I needed to use a bent coat hanger to work as giant sowing needle to pull the threads up. It also helped when I was threading the arm wires through the shoulder sockets and up through the top of the neck.
So, if you have done this right, you should have 4 pieces of wire sticking out of the neck of the skeleton.
Tie them off around the neck bone and put the skull on top and you are ready to hang your skeleton where ever you like!
I used some left over wire to hook these guys to my window shutters and the gutter. Word of warning: do not climb ladders by yourself! Get someone to hold the bottom or take you to the emergency room!
In the future, I will use black coated wire, since I am concerned that the picture wire might scratch the paint or rust a bit.
Happy Halloween everyone!
3 comments
Aug 11, 2011. 9:26 PMpheaney says:
I was wondering how to tweek my house for halloween. This is awesome and inexpensive....Will have several of them crawling on my house...Thanks
Oct 24, 2010. 1:02 PMsnafell says:
Picture wire is usually brass so no need to worry about rust and is also softer than steel.
Andy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:mckeephoto
Commercial photographer with a need for some diy projects with the kiddies!
