Introduction: Clock With Thermometer Using Arduino, I2c 16x2 Lcd, DS1307 RTC and DHT11 Sensor.
Hello! It's been a while I've didn't posted anything on Instructables, but now I made a simple project that I've seen on internet in various forms. I managed to build a code using other codes I've found on internet and I got to say it's working good.
For this project you need:
- Arduino Uno
- 16x2 LCD with i2c module
- DS1307 RTC
- DHT11 temperature and humidity sensor
- a bread board
- some wires for connections.
As you can see the RTC is homemade because I had a DS1307 chip and a battery extracted from an old german electronic cash registering device.
So the connections are very simple:
The RTC and the i2c LCD are connected to A4 pin (SDA) and A5(SCL) and DHT11 sensor is connected to D2 pin. DHT11 has 4 pins, but only 3 are actually used. First pin is Vcc, the second is for data and the forth pin is for ground. As I said, connect data pin of the sensor to D2 on Arduino.
Now, the hardest part: the code. !!!DOWNLOAD THE ORIGINAL SKETCH FROM HERE!!!
I've tried some sketches I've found on internet, but there were alot of errors caused by incompatible libraries and so on. I managed to build a code made from parts of other codes and it's working like a charm now. There is a single problem though. You can find in the sketch a bit of code for displaying first 3 letters of the week day, but for some reason it doesn't work. Instead of those letters it shows some unknown characters and it's pretty ugly. I suspect that is a problem caused by i2c communication because in standard connection (4bits) it works without problems.
My inspiration came from this page http://arduino-info.wikispaces.com/PROJECT-Temp-Humidity-Display, and this page http://www.ucontrolit.tv/184/
This is the library used for this project http://arduino-info.wikispaces.com/file/view/DHT11.zip/390039522/DHT11.zip and don't forget to use the new LCD library that can be found right here https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads (when you add this new library in the folder, delete the old LiquidCrystal folder!)
And this is a PREVIEW of the code:
________________________________________________________________________________________________
/* YourDuino.com Example Software Sketch
DHT11 Humidity and Temperature Sensor test
Displayed on I2C LCD Display
Credits: Rob Tillaart
terry@yourduino.com
Combined with:
Mark Johnson's code
http://uControlIt.tv
December 2012
License: GNU General Public License
Modiffied by Timofte Andrei ( http://timofteandreidiy.wordpress.com )
January 2014
/*-----( Import needed libraries )-----*/
#include
#include
#include
#include
#include
//const char* zile[] =
// { "Lun", "Mar", "Mie", "Joi", "Vin", "Sam", "Dum"}; //days of the week in romanian (not used)
const char* luni[] =
{"Dec", "Ian", "Feb", "Mar", "Apr", "Mai", "Iun", "Iul", "Aug", "Sep", "Oct", "Noi" }; //months of the week also in romanian
byte termometru[8] = //icon for termometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte picatura[8] = //icon for water droplet
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
/*-----( Declare objects )-----*/
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x20, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE); // Set the LCD I2C address
dht11 DHT11;
/*-----( Declare Constants, Pin Numbers )-----*/
#define DHT11PIN 2 //dht11 signal pin connected to D2
void setup() /*----( SETUP: RUNS ONCE )----*/
Wire.begin();
lcd.begin(16,2); // initialize the lcd for 16 chars 2 lines, turn on backlight
lcd.backlight();
lcd.clear();
lcd.createChar(1,termometru);
lcd.createChar(2,picatura);
// part code from http://tronixstuff.wordpress.com/
Wire.beginTransmission(0x68);
Wire.write(0x07); // move pointer to SQW address
Wire.write(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
Wire.endTransmission();
// end part code from http://tronixstuff.wordpress.com/
setSyncProvider(RTC.get);
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
afisare_temperatura(); //displaying temperature
data_si_ora(); //displaying date and time
void afisare_temperatura()
int chk = DHT11.read(DHT11PIN);
lcd.setCursor(1, 1);
lcd.write(1);
lcd.setCursor(3, 1);
lcd.print((float)DHT11.temperature, 0);
lcd.setCursor(5, 1);
lcd.print((char)223); //degree sign
lcd.print("C");
lcd.setCursor(9, 1);
lcd.write(2);
lcd.setCursor(11, 1);
lcd.print((float)DHT11.humidity, 0);
lcd.print("%");
delay(2000);
void data_si_ora()
tmElements_t tm;
(RTC.read(tm));
lcd.setCursor(0, 0);
afisare2cifre(tm.Hour);
lcd.print(":");
afisare2cifre(tm.Minute);
lcd.setCursor(7,0);
afisare2cifre(tm.Day);
lcd.print(" ");
lcd.print(tm.Month[luni]);
lcd.print(" ");
lcd.print(tmYearToCalendar(tm.Year)-2000);
// lcd.setCursor(12,1); // this code is used for displaying day of the week
// lcd.print(tm.Wday[zile-2]); //it's disabled because for some reason it doesn't work on i2c display
void afisare2cifre(int numar) { //this adds a 0 before single digit numbers
if (numar >= 0 && numar < 10) {
lcd.write('0');
lcd.print(numar);
/* ( THE END ) */
____________________________________________________________________________________________________
- Arduino Uno
- DS1307 RTC
- a bread board
terry@yourduino.com
Combined with:
Mark Johnson's code
December 2012
January 2014
#include
#include
#include
#include
#include
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
dht11 DHT11;
Wire.begin();
lcd.backlight();
lcd.clear();
lcd.write(1);
lcd.print("C");
lcd.write(2);
lcd.print("%");
delay(2000);
void data_si_ora()
tmElements_t tm;
(RTC.read(tm));
lcd.print(":");
lcd.setCursor(7,0);
lcd.print(" ");
lcd.print(" ");
lcd.write('0');
lcd.print(numar);
/* ( THE END ) */
