Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Are they quiet along the floor?
My only other comment is you unconventional framing grid technique means that if you ever want to put an outlet or wall switch on one of those closet walls you will have to open up the drywall and drill through the horizontal framing members to get the wiring in. Some building codes require at least one horizontal member in between wall studs as fire blocks, but they aren't needed in the type of closet walls you have built.
And actually the unconventional framing method was all part of the plan. Before deciding to go to IKEA, which was when the frame was built, I had initially planned to put shelves along all of those horizontal framing members. This wasn't the case for the "her" closet since she found everything she wanted at IKEA but on the other closet the framing all served a nice purpose and resulted in some sturdy shelving. Electricity won't be an issue because there are ceiling lights right outside the doors of the closets which aim into the closets. And also I have some nice motion lights that will go on the inside above the doorway.
