3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cloth Covered Banana Cables
Step 3Cover the Cable
Cover the Cable
Slip the shoelace cover over the wire or cable.
Holding the cable, gently push the cover where the end of the wire is.  Use three fingers and refrain from squeezing to prevent the cover from collapsing.
Feed the cover all the way onto the wire, allowing enough extra at each end to allow you to strip the wire and attach the connector.  This may change depending on the connector you use.
1 comment
Sep 9, 2010. 7:12 AMthankey says:
Could you attach the core to the wire before removing it then pull the wire through as you remove the core in one step?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Aud1073cH
