3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cloth Covered Banana Cables
Step 6Prepare and Assemble Connectors
Prepare the Connectors
I put heat shrink tubing over my connectors to change them black, to add a rubber grip and to give a little strain relief to the cord.  I used about 1.5in. long tubing over the 1in. long connector. You may need a different size if you are using different connectors.
      These connectors use set screws, so I poked a hole in the tubing to allow the screw to go through. I used an awl, but you may use whatever thin sharp object you like if you need a hole.
  For connectors without set screws, or if you prefer the set screw to be hidden, especially if you plan to use your patch cables for high voltage, you should not poke holes, but put the heat shrink on at the last step instead.
Assemble the connectors.
Insert the wire into the banana, slide the sleeve over, and insert the set screw.  Of course other connectors may be assembled differently.
     For many connectors you will need to remember to slide the sleeve over the wire first before screwing down or soldering the connection.
1 comment
Sep 9, 2010. 11:15 PMzulfiqaradil says:
this idea was good but little bit of mistake its not isolated at the point of screw in your discribe procedure in step 6 you first screwd the cable in banana pin then put the heat-Shrink sleave on it
Sep 14, 2010. 1:05 PMjeff-o says:
You could cover the screw with a layer of sugru!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Aud1073cH
