loading
Picture of Clothespin Coaster
Heres an easy, inexpensive, and functional caster, made with two clothespins.
Step 1: The materials
Picture of The materials
First you need two wooden clothespins.
Step 2: Disassembling the pins
Picture of Disassembling the pins
Take apart the two clothespins, but keep the springs. you can use them for replacements for the mini peg gun: http://www.instructables.com/id/DIY-Peg-Mini-Gun/.
 Now that you have the two pins apart, time to move to step 3.
Step 3: Assembly of coaster
Picture of Assembly of coaster
this step is simple, just look at the pictures. to put them together, you need to put the small end of the clothespins in the slot on the backside of each one.
Step 4: Finish
You can now glue or decorate your coaster.
meddler4 years ago
You know, I was trying to think of a way to add a bit of space between my electronics so they get better air flow and not heat up quite as fast. This will work perfectly! Thanks for the idea. :) Also, I think a bit of scrap felt on top of the coaster would get the drips that run down the side of a glass. Just a thought.
