Cnc Plotter With Adruino
2,599
67
6
Published
Introduction: Cnc Plotter With Adruino
this project is very easy to make and very cheap and will u will learn something new here is a clip of the working
if you like my project andfor better view watch it on youtube please like and subscribe my youtube channel for more awesome updateshttps://www.youtube.com/watch?v=kEy7BfabhlI
Step 1: Parts for the Project
so the part u gone need for this project are
1. 2x old PC DVD Writer
2. Arduino nano (http://amzn.to/2mmT5jF)
3. Small servo motor (http://amzn.to/2mVok9w)
4. L293D (http://amzn.to/2lWCbgj)
5. Zero PCB (http://amzn.to/2n4DUQq)
Step 2: Assembling the Components
first u gone attached those pins and shield for ic's on the PCB zero
and solder it
(note: count the number of pins on arduino nano and then cut the pins)
Step 3: ASSEMBLING THE USB AND 3 PIN FOR STEP MOTOR
Step 4: Making of Arm for Cnc
1.now u gone need a piece of acrylic and cut a small part of 5x3cm and hole in it 0.5cm approx
2. now take a 0.5cm rod and and 18cm long and bend it from 11cm as shown
3 now take 2 piece of acylic 3x4 glue on the ends of the long piece
4 glue the servo on the back at 2.5cm
5 now u need a small spring and the glue the small piece with rod
Step 5: Soldering the Circuit
now u need to solder and connect the components from the diagram it would hardly take 2 hours
Step 6: Making the Body of Cnc
1next thing u need is to take thing out step motor assembly of your old dvd box
2now take a wooden plank 25x22cm and two wooden piece of 18x5cm and then glue them 9cm apart and glue the step motor assembly for y-axis
3 then place the other step motor assembly down for x-axis
Step 7: Assembling the Arm and Giving Connections
now glue the arm and solder ther step motor circuit and solder some pins
Step 8: Board Attachment
1.Now Attach the Thin Wooden a Pcb Sheet to the X-axis and Make Sure the The Laser Assembly Is Near to the Y-axis
Step 9: Now Attach a Pen With Rod and Place a Paper With Paper Pins
Step 10: Programing and Run the Software and Working
https://www.mediafire.com/folder/mjpktcfixg4al/CNC_all_Data
here is a link for all the neccesary software and intructions are given with it even if u face problem u can ask me in comment below
here is a clip of the workinghttps://www.youtube.com/watch?v=kEy7BfabhlI
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    6 Comments
    The addition of the spring is brilliant.
    thanks buddy if u face any difficulty i am here to help you
