3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coat Hooks from Cheap Spoons
Some time ago went shopping to buy some coat hooks. I was appalled by the cost of them so decided to make my own.
It occurred to me that cheap stainless steel cutlery might just do the trick. My idea worked quite well I think. And with some more thought and care I believe they could be made to look really good.
By the way. I'm sure I can't have been the first one to come up with this idea, but I haven't seen it before.
All you need to make these simple hooks are:
  • Spoons. As many spoons as you want hooks obviously. I guess there would be no reason not to use forks or splades or even splorks if that's what you like. I got some really cheap spoons from the two dollar store. Old silver could work nicely too. Make sure the handles are fairly strong, you don't want them to sag under the weight of a winter coat.
  • A hammer and something heavy to use as an anvil. I actually used an anvil as an anvil and it worked brilliantly.
  • A drill.
  • Screws and something to drive them with.
  • Something to attach your hooks to. This could be a wall, or a slab of timber which could be dressed up nicely and then attached to a wall, or a piece of furniture.
Step 1Flatten the spoons
Flatten the spoons
Carefully flatten your spoons with your hammer. Try not to make too many nasty dents in them. A slightly rounded hammer makes it easier to be neat.
10 comments
Feb 25, 2012. 4:59 PMwildviolets says:
wonderful idea...thanks for sharing...
Feb 10, 2012. 3:23 PMmeddler says:
I love the idea. Sadly I think the heavy coats I have would bend the spoon the first time I tried to use it. However I do have a few fedora hats I like to wear and this would be a perfect idea to use for them.
Feb 4, 2012. 6:56 PMjarikcbol says:
Very slick. You usually can get silverware cheep at thrift stores (may take some work to find enough that match though). If you are making these, and have a drill press, you could even find a way to drill them without flattening them, and put the concave side of the spoon towards the wall, might make for a neat effect.
Jan 27, 2012. 10:52 AMJobar007 says:
Is there a reason why you wouldn't drill before bending? It seems to be a better way to get a good hole without the handle interfering.
Jan 26, 2012. 5:05 AMrimar2000 says:
Very clever!
Jan 26, 2012. 9:39 AMPenolopy Bulnick says:
Awesome idea! Looks great. Do you have issues with things too heavy on them? I always seem to bend my spoons.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:cammers(pumpmaster)
"There is always more that one way to skin a cat." "What could possibly go wrong?"
