Coat Rack / Christmas Stocking Stand
Published
Introduction: Coat Rack / Christmas Stocking Stand
I took some scrap 2x4s I had lying around to make this. First I cut them down to 6' each and ran them through my planer. (I recommend using a good 4x4 for the pole if you have one)
Ingredients
1. 2 8' 2x4s or 1 6' 4x4 and 4 1' 2x4s
2. 3' screws (about 20 or so, less if you use a 4x4)
3. White acrylic paint, or latex
4. 1 2" wide (or 3") red ribbon
Step 1: Build the Pole
I cut 2' off of each pole to bring it down to a nice 6' tall pole. I ran both of the 2x4's through my planer to even them up a little. Once that was done I used screws and made sure I had a flush end for one side.
Step 2: Shaping the Pole Some
It was a bear to run it through my router, but between the router and a bit of work with my palm sander, I was able to smooth the edges and get a nice rounded edge.
Step 3: Making Some Feet for It
Those 2' pieces we cut off earlier get used here. I cut both of them in half and then used a miter saw to make an angled cut in the top. After very carefully attempting to attach them all evenly so the stand wouldn't wobble, I sanded them down too.
Step 4: Paint It White
Paint the entire pole with a decent white acrylic. Best to do two coats. I didn't paint the very bottom of it. I'm considering later on maybe coating the bottom with some Plasti Dip.
Step 5: Hooks and Red Ribbons
Add your hooks, then spiral wrap the red ribbon around it.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Yep, lights would be pretty nice on it.
