Step 6Cut the cans and place on the Styrofoam
Make another template so that you can easily place the cans on the Styrofoam, you will not need glue if you do this right, the can fit well on the Styrofoam. After you cut the cans you may want sand the bottom of them down to avoid being cut.
If you want to place cans in the middle you can do that also, I only did the outer edges to save some time.
The corner cans are little but trick you should only cut about half as much out of the can.
Add Comment
