Coca Cola Bottle Night Light.
Introduction: Coca Cola Bottle Night Light.
I decided to make an LED nightlight out of a round coke bottle.   I had this idea before I saw the other instructable by lambsb, but I noticed that he/she used a flashlight bulb instead of an LED, so I figured I'd go ahead with this.
Step 1: What You Will Need
You will need:
*Round coke bottle
*Switch (I prefer the 1/2 inch push button)
*Button battery with case (small size)
*Soldering Iron and Solder (mine is taped together for this instructable)
**The cost of the materials was about $3.00 not including the coke bottle.   If you order the materials off of the internet, it will cost a  LOT less money.
Step 2: Drill the Hole.
First you want to drill (or melt) a hole in the cap.  My switch is 1/2" so of course I drilled a 1/2" hole.
Step 3: Insert the Switch
Now insert the switch into the hole.  Don't forget to attach the nut that comes with it.
Step 4: Build the Circuit
Connect the positive side of the battery to one of the switch terminals (it doesnt matter which one). Connect the negative side of the battery to the negative (short) side of the LED. **NEVER solder directly onto a battery or it may explode!  Solder to the battery case WITHOUT the battery installed**
Connect the resistor to the other switch terminal and connect the other end of the resistor to the positive (long) side of the LED.
My photo isnt very good because I used scotch tape (I know better, but it wasnt permanent!)   I also didnt have the resistor connected.
Second photo shows a crude schematic.
Step 5: Put It All Together
Now carefully guide your circuit into the bottle, screw on the cap and turn off the light and turn on your new night light!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    Very nice instructable, thank you for it! I saw lambsb's first, but I prefer yours... now I need to find some empty bottle :)
    Thanks.  I could have done it better but at the time I didn't own a soldering iron so thats why I used tape. lol.
    By the way, don't use tape to piece together circuits, it's dangerous even if you are only using small batteries.  I only did this for the instructable, but then took it apart until I could get a soldering iron.
    I also forgot to add the resistor, although I'm not sure if you would really need one or not.
    I always add resistors where needed... so I will definitely be adding one here lol
    That looks really cool! Where did you get the round Coke bottle?
    Walmart.  The other user who made a similar lamp had 2008 on his bottle, so I assume they are only sold on holidays.   I didn't realize they had them last year.  Mine is 2009.
     I got one this year at walmart to
     Nice light! Although, technically you don't need the resistor since white LEDs draw an average of about 3 - 3.5v, and the coin battery only supplies 3v.
    In this case the resistor is for safety and is only used to regulate power surges, not "pull down" voltage. The author does not state the size of the resistor so I am assuming it is very small.
     Ohh, okay, I see now, thanks.
    At first I thought you made the typical cylindar bottle into a spherical bottle. I've never seen one of these spherical bottles sold in Michigan. When were they sold?
