Step 3Attaching the Backpack
Gently slide it out of its box onto a 'gas stage' (don't know what these are called but look at the photo). This gas stage emits CO2 so the cockroach stays asleep.
Carefully clip off the wings to avoid cutting the exoskeleton. Cut far away from the attachment point and work your way closer so as not to damage anything else.
Put a small drop of super glue onto your backpack and attach it on the second segment (see picture) of the cockroach. DO NOT use too much glue or you will glue the segments together.
Turn off the gas and let the cockroach wake up. Make sure it's in an arena or it might run off with your backpack.
To remove the backpack, knock the cockroach out again, put a tiny bit of solvent (like acetone) on the tip of something and dab it around the edges of the backpack. It will come loose.
Let the cockroack wake up and return it to its cage. See my instructable on how to care for cockroaches:
http://www.instructables.com/id/EHVK19L763EQHO8Y8D/
Add Comment
