3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coconut Bird Feeder.
Winter is a hard time for birds. Feeding them with a mixture of fat and seeds helps them through this period.
Here’s a simple Instructable that will show you how to make a bird feeder based on a coconut in such a way that the fat-seed mixture is always protected from the rain and that larger birds can not feed on it.
It is particulary suitable for: Nuthatch and Great Tit.
You will need
  • 1/2 coconut.
  • A wooden stick (lenght 30 cm, diameter 1 cm)
  • A piece of iron wire or rope.
  • 1/4 l fat and a handful of seeds. Use fat that is solid at room temperature. In this way, when the temperature rises outside, you don’t loose all the fat at once. I have used the  fat (not the meat!) from a dish called Confit_de_canard (duck confit). Briefly the dish is duck, submerged in fat and then canned. It is this fat that I have used.
  • Some glue to glue the stick in place.
How it's made:
Take a 1/2 coconut. Drill a hole through the top of the coconut (the diameter should be equal to the diameter of the stick).
Add some glue to the top of the stick and insert it into the coconut. Let it dry.
Drill a small hole in the top of the stick (to attach the iron / wire).
Melt the fat, add the seeds and pour it into the coconut. Let it solidify. Done!
10 comments
Feb 15, 2011. 11:56 AMKiteman says:
You got a nuthatch in your garden?
>jealous<
Feb 15, 2011. 12:13 PMKiteman says:
No, just very shy.
Feb 15, 2011. 12:28 PMKiteman says:
That's more than lucky - they are genuinely good shots.
Feb 15, 2011. 4:30 AMNinzerbean says:
You are very generous to use left over duck confit for bird food. On second thought doesn't that seem a bit cannibalistic to you?
Feb 15, 2011. 4:58 AMNinzerbean says:
That's OK, I think you have, I always thought duck confit (I've never been so lucky as to have tried it) was duck legs cooked in duck fat. Anyway, lots of birds eat other birds. There is a lot of controversy in the US about feeding birds in the winter or not. You will probably hear some of it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:bertus52x11
Check out The CameraClip, a commercial spin-off of one of my I'bles at www.cameraclip.eu OR in the Instructables Store!
