I assume you have coconuts without husks.
ITEMS USED:
" Drill + 2 circular drill bit
" Sand Paper (coarse + fine) + Steel Wool
" Belt Sander (optional)
" Safety Glasses
" Flat-head Screwdriver
" Canvas Drop-cloth (or any fabric)
" T-square or other measuring/aligning tool
" Pencil
" Stencil/Stencil material
" Paint + Paint brush
" Stuff for Hemming (Regular Weight Stitch Witchery- iron-on) Hot glue
" Scissors
" Xacto Knife
" Wax (optional)
" Elbow Grease
Remove these ads by
Signing UpStep 1STEP 1: Coconut time (drain, cut, and clean)
Put on your safety glasses. Using your drill & 2 circular drill bit, begin cutting discs around the coconut. Youll probably get 6 or more discs per coconut depending on how close you cut and the size of your coconuts.
Be careful. As soon as you feel the bit cutting easily its time to back off. You want the disc to stay attached to the meat because you can then pry the disc from the meat with your screwdriver. Dont worry if meat is still attached, you can use your screw driver to cut/scrape/pry the meat away.
Make as many discs as you can. You can always use them for something else later. Also, the scrap coconut pieces work for other projects, too.
(WARNING: The disc may actually lodge in the 2 circular bit. If that happens, take the bit off the drill, unscrew the nut holding the circular bit to the shaft, and pull apart. You will then be able to easily get the disc out. I counted 5 times that I had to go through the process.)
comment
Add Comment
seamster
says:
Add Comment
