Coffee Burr Grinder Attachment for KitchenAid Mixer
 by jeffkobi
Contest WinnerFeatured
I just recently started to enjoy a cup of coffee in the morning.  I had a "helicopter blade" coffee grinder for years and decided to upgrade to a cheap hand-crank burr grinder (Kyocera CM50 - $39 on Amazon).  This grinder has conical ceramic burrs that produce a MUCH more consistent grind for drip coffee than my previous grinder.  I was astounded that I could actually taste the difference - much smoother once I found the right grind setting!
I then started looking into motorized burr grinders.  Most high quality grinders were $500+.  The cheapest conical burr grinder I could find was the Bodum which was $80.  Not bad, but I thought, why don't I make a burr grinder attachment for the KitchenAid mixer that's taking up a ton of my counterspace?
When coming up with the design, I held myself to these rules:
 1. Priced below the $80 Bodum
 2. Meet or exceed the grind quality of the Kyocera CM-50
 3. Able to be made with tools a "tinkerer" might have - no fancy CNC milling machine parts
 4. Easy setup/removal (less than 15 seconds each)
NOTE: I designed this for my Kitchen Aid 600 mixer I have a design in mind that would work for all other square-drive Kitchen Aid mixers and will post shortly.
Step 1: Parts and Tools
Essential Parts:
 1. Kyocera CM-50 ceramic burr coffee grinder ($39)
 2. Milescraft 90 degree drill adapter ($15)
 3. 3/8" x 1.25" long coupling nut ($0.99)
Parts/Materials that Can be Substituted:
 4. 3/4" x 1/8" thick aluminum bar
 5. 3/4" pine board
 6. #12 x 3" long wood screw
 7. #10 x 1" long wood screws
 8. 1/2" x 1/4" long copper tube
Tools:
 - Hand drill
 - Jig saw
 - 3/8-16 die (cutting screw threads)
 - Bench grinder
riverpro says: May 18, 2013. 12:21 PM
Please keep me posted when you do shaved ice attachment! Thank you.
gumby_kevbo says: Apr 4, 2013. 1:06 PM
This is a great idea. My parents had a kitchen-aid from the 1950s. The attachments were much stouter back then, cast aluminum instead of plastic. Re. the other commenter about food processor: Kitchen-aid does sell a set that has graters and slicers, the modern plastic housing tends to flex and allow stuff to get between the rotor and housing though.
Be careful with using the K-A for a power source. My dad had the great idea to use it to run an ice-cream freezer. About the 3rd batch of ice-cream the kitchen aid's armature burned up. So after dad rewound the armature, the adapter got pitched in the trash to make sure it didn't get used again. Running at high torque for over a half hour at a stretch is just too much work for too long for a motor that has no cooling air going through it (so it doesn't suck in flour!)
jtmcdole says: Feb 16, 2012. 4:46 PM
Black & Decker CBM220, $35 electric burr grinder. It uses metal disks, with one fixed and the other one spinning.
jeffkobi (author) in reply to jtmcdoleFeb 17, 2012. 2:28 AM
I did see the CBM220 but decided not to use it as a competitive benchmark because it only had 15 reviews on Amazon - and of those reviews was rated 2.5 stars. The Bodum had 350+ reviews and was rated an average of 4.5 stars - by far the highest rated, most reviewed burr grinder under $100. Again, I'll say that I'm relatively new to the world of coffee and really don't understand the nuances of flavor . . . because of this I just had to trust reviews and ratings online. I do personally have the Bodum grinder and have zero complaints!
mattone in reply to jeffkobiOct 29, 2012. 9:42 AM
Great project!
I have been into coffee for years, upgraded my equipment part-by-part over decades and have a good Rancilio grinder and espresso machine at home (Silvia and Rocky). However, Its frustrated me for years that my KitchenAid mixer has been sitting idol while I use a grinder to do something for which KitchenAid surprisingly does not have a solution. Years ago I purchased KitchenAid's Grain Mill attachment expressly for the purpose of grinding coffee. Its a burr grinder with a hopper and its worked well once it was calibrated. This led to lots of wasted coffee since each time you took the attachment on and off, you had to repeat the calibration.
I like where you're going with this project. Please update soon.
sarah05148 says: Feb 18, 2012. 4:25 PM
I think a series of instructable/ mods for the Kitchen Aid motor shaft would be really a great service to the community. I just bought a food processor for my daughter and it puzzled me why there was no attachment for that ( besides the obvious one that they make a stand alone processor). any takers? the coffee grinder is a great inspiration, thanks.
jeffkobi (author) in reply to sarah05148Feb 24, 2012. 1:29 AM
Great suggestion! I definitely think the KitchenAid attachment is an untapped DIY opportunity! Sadly, I'm short on new attachment ideas, BUT extremely eager to develop any new/popular attachment suggestions.
Anyone who's reading this - please let me know if you have a KitchenAid attachment idea you'd like me to work on. Please keep in mind that the KitchenAid output drive is relatively low-speed(RPM), but high-torque
Thus:
- Attachments like a high-speed blender would require an expensive gear box to multiply the RPM's to an acceptable level. At that point, it may be more cost effective to just buy a quality blender for ~$100
- An example of an ideal attachment would be an ice-shaver/shave-ice/italian ice attachment . . . which spins a large block of ice at low speed. Hmm, now that I think about it, that's actually a great idea (I grew up in Hawaii and love shave-ice). Stay tuned for a shave-ice attachment!
Chinasaur in reply to jeffkobiMar 12, 2012. 4:26 PM
This is a great instructable! I'm interested in Open Kitchenaid attachments. The only other example besides your project I've found so far is this rotisserie.
As you've identified, the KitchenAid is best suited for low-speed high torque output. But I think it could be useful to extend applications beyond the kitchen; there's no reason you couldn't use this powerful, expensive motor in other applications.
I'm also interested in trying to make this simpler for people without a lot of tools at home. I wonder if there's a custom CNC or even 3D printing resource that would make coupling the drill attachment to the KitchenAid simpler.
Chinasaur in reply to ChinasaurMay 20, 2012. 2:21 PM
I created a Google Group to share notes on DIY Kitchenaid attachments: https://groups.google.com/forum/?fromgroups#!forum/kitchenaid-diy
spike3579 says: Apr 10, 2012. 4:24 PM
I liked your idea so much I made a version of your coffee grinder. There's an instructable here and a blog post here.
helen41 says: Feb 24, 2012. 5:57 PM
Congratulations on the win! This is an excellent instructable
barefootbohemian says: Feb 18, 2012. 10:08 AM
I think you are on to something! KitchenAid really seems to like having all kinds of attachments that don't always do just what they are supposed to do, but this actually works! Great Job!
spark master says: Feb 17, 2012. 6:47 AM
Over my wishes my wife bough a cuisinart for 20 bucks (sale item plus coupon), errr I had to appologise best coffee ever it is a burr machine DBM8. Perfect coffee always for 20 bucks, no muss no fuss. fill ,set, turn on, done! For perfect beans I suggest BJ Wholesale's brand 100% Columbian whole beans .
MMMMMMMmmmm
gunna have a cup in a few minutes
Nice instructable though,
ciao
FredicvsMaximvs says: Feb 15, 2012. 5:12 PM
Oh man, this is great! I've always wondered why KitchenAid doesn't make a decent coffee grinder attachment for my mixer. AND I have the same burr grinder! I'm definitely going to have to give this a try. Thanks!
wgwalkerii in reply to FredicvsMaximvsFeb 16, 2012. 9:50 AM
Definitely cool, but we bought a KitchenAid Coffee grinder (Stand Alone, not an attachment) some time back, and grind all our beans in it.
Thats why they don't make an attachment too probably, they have a Coffee Grinder on the market already.
Kudos for the ingenuity though.
jeffkobi (author) in reply to wgwalkeriiFeb 17, 2012. 4:23 AM
Yep, did a lot of research before starting this project and came to the same conclusion you did: KitchenAid already has a ~$200 standalone burr grinder, so why sell the same or better quality grinder attachment as a competitor (most attachments are ~$100 or less)?
That being said, I do think there is a huge cross-section of people out there that have an under-utilized mixer, love coffee, and value their counterspace (who doesn't?).
That being said, my next KitchenAid Burr project will use "professional" ø68mm Mazzer conical burrs. Will definitely be an "open source" design where the CAD is freely distributed. Send me a private message if you're interested in helping - be sure to include which CAD systems you prefer!
cmjake007 says: Feb 16, 2012. 2:37 PM
no doubt to your ingenuity, kudos. I love good coffee, so quality grinder is a must. I just think there are better alternatives to tying up an amazing mixer. The effort to break it all down and set it up when you want to mix something, maybe a great bread dough. I kinda like the hand crank mill as it was, but to each his own, few turns, back it goes in the cupboard, but very nice job building what you wanted !! What I need is how to build a kitchenaid out of my coffee mill !!
jeffkobi (author) in reply to cmjake007Feb 17, 2012. 3:50 AM
I couldn't agree with you more about not wanting to tie up an amazing mixer! Just updated the my design rules to explicitly state this goal: less than 15 sec for setup/breakdown.
After re-reading the instructable, it's definitely not clear just how quick this action is. There are only three points of contact with the mixer, one thumbscrew and two 3/8" pins. Once you remove the thumbscrew (came with mixer), you just have to pull on the drillhead and lift the entire assembly up to remove it. Attaching a photo . . . will hopefully upload a video shortly. Thanks for your comment!
mdeblasi1 says: Feb 16, 2012. 2:47 PM
As I watched I could smell coffee grinding. : )
sgt_rock says: Feb 16, 2012. 2:23 PM
Yes, I have a Cuisinart Burr Grinder. But if I didn't I'd make this one! Very cool!
cougarmandan says: Feb 16, 2012. 12:49 PM
I can't imagine any cooler accessory for your Kitchen Aid mixer then installing a drill attachment. That is too cool.
skuli.arnlaugsson says: Feb 16, 2012. 8:40 AM
I have the same Grinder and have been trying out attaching it to my hand drill, but this is a much more elegant solution. Now I just need a Kitchen Aid :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
