3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee Cup - Honeycomb Sandwich Structure
So you think your coffee is strong? Wait until you have tried your coffee cup!
"A Honeycomb core is an array of hollow columns made of sheet material which is used to separate the two facings of a sandwich structure".
So why not make one of Coffee Cups and enter the Coffee Cup Challenge?
This I'ble will show you how to make a honeycomb panel as a building block for your future projects.  If you like it, don't forget to vote for me!
Note
Where I live, paper cups are somewhat rare, so I have merely made a beam and tested it.
My project has ended by testing this beam. If you want to take it to the next level or if you have an awesome idea, feel free to use this information and even post it in the Coffee Cup Challenge as well (some credits would be nice though).
Step 1What do you need?
What do you need?
It's a great misconception that you need fancy materials to fabricate composite materials. Nature is full of extraordinary examples.
You will need:
* 45 coffee cups
* two triplex strips of 90 x 20 cm (thickness 2 mm).
* Glue.
The dimension of the strip was more or less determined by the fact that I could only get hold of 45 cups (3 rows of 15 cups).
58 comments
1-40 of 58next »
Aug 18, 2011. 5:06 PMIOPort51 says:
this is great, good thinking! I think these would not be as thermally resistant or as strong as SIP's but a lot more cost effective for a lot of purposes. I am thinking about farm structures, chicken houses, rabbit hutches, small barns. Not taking away from the Styrofoam cup concept but free association brings me to the next obvious choice being aluminum drink cans. You could set a house on one of those!
I am looking forward to your next project, whatever it may be.
Jun 6, 2011. 11:59 AMBiggsy says:
You know.. i think i'm going to set this as a challenge for my Scouts! hehehe
Jun 6, 2011. 1:34 PMBiggsy says:
I shall do :)
Sep 14, 2010. 8:33 AMtulekah says:
this is a TORSION BOX, way way cool. i'm thinking of two sheets of glass bound by epoxied glasses!
Apr 21, 2010. 5:27 PMyoshhash says:
 If you filled the voids (outside the cups, not inside) with expanding foam, or some other adhesive, light, form-filling material, you would eliminate the "weak points", which is the only thing wrong with this very BRILLIANT idea of yours.  Not only that, but it would then be an insulating material.
Sep 14, 2010. 8:45 AMtulekah says:
expanding foam expands and will dent the cup walls. this is like the old "stand on a pepsi can" trick.
May 2, 2010. 8:19 AMcogni says:
What is a "triplex strip"?
Could one just use corrugated cardboard?
If so, coroplast would also work (corrugated extrusions of plastic) but it is more expensive.  $10 for an 8' x 4' sheet here, from a sign shop.
Sep 14, 2010. 8:42 AMtulekah says:
dumpster dive cardboard boxes. cut into 4" strips (cut across corrugation) and roll (pop-can) into tubes, glue between face cardboard strips (the corrugation lines should run parallel to the longest dimension.
you can make the faces stronger by doubling the face, or by cutting the faces on the bias with the corrugation at right angles to each other.
Jul 27, 2010. 2:24 AMbeehard44 says:
why not put scrunched up paper as filling in the coffee cups to make them stronger? maybe slather the sides with concrete for building material? just suggesting
Jul 1, 2010. 2:05 PMStevie89 says:
Coffee cups hard too find? lm a Canadian.. in my city, Saint John NB, we have like 25 Tims alone, 3 starbucks, 4 Java Moose.. coffee cups are EVERYWHERESSSSS :-S
May 9, 2010. 11:25 AMzeeebus says:
I was thinking the same thing about the walls.  Much like a SIP, but homemade and less styrine.
I can imagine building a 8' tall frame using studs the same width as the height of the cup (If cup is a medium, it will be xx inches tall, therefore your stud should be a 2 X xx inches wide stud.).
Put studs on 4' centers. (4' is probably too wide actually.  I think, you would have to place them just inside the width of the plywood so when you are actually attaching the panels to the framing of the house you can nest the panel into the framed wall bay and nail the existing frame to the panel frame.)
Temporarily screw a sheet of 4x8 OSB onto the frame and flip it over so the OSB (Plywood) is on the bottom of the frame. Lay the frame at a slanted angle (the laying angle of a drafting table, say).
The angle would allow you to stack cups onto the entire field of the plywood between the studs with cups.
Next, you would take a second sheet of OSB and, using a roller or air pressurized sprayer(not disposable aerosol type, but the kind used in finishing booths at furniture and body shops), coat the ply with laminate adhesive according to manufacturers instructions.
Apply this sheet (when it is good and tacky and ready) to the frame.  Screw it permanently to the studs. Ideally (I'm making this up as I'm typing, so bear with me here) Ideally the contact of the cups onto the glued surface would be pretty uniform.  Maybe a stud that is just a hair narrower than the height of the cup would allow for the adequate uniform pressure to contact all the cups.  I guess you'd have to be careful not to crush them, though.
Next, you would flip the entire 4x8 coffee cup "sandwich" over so that the adhesive coated plywood is on the bottom.
Remove the first sheet and coat appropriately.  Re-attach to frame, and VOILA!  You've just made your own Coffee Cup SIP! (Oh, (S)tructural (I)nsulated (P)anel)
The load is carried on the studs.  I think...By all means, use at your own risk... Any engineers out there should  probably put me in my place here.
I think the real SIPS have the studs a small distance from the edge of the ply, which allows them to nest with a second stud already attached to the bottom plate of the wall (the horizontal 2X___" that is already fixed to the floor of the structure)
Any thoughts?
Just a thought.
Great Instructable!!
May 20, 2010. 1:17 PMzeeebus says:
Darn.  I was afraid that was what was happening!!!
Thanks for the reply.  Guess this gives me the summer project I was wondering about.  We'll see.  I would really like somebody to tell me if this sort of thing would be dangerous at all.  I'm concerned about structural soundness primarily, and fire secondarily.  Anybody???
By the way...you should have definitely beat the coffee cake entry and winner.  I didn't read any of the comments on the thing because I didn't think it was all that great of an idea.  Now that I've looked at it, I'm wondering if the wax on the inside of the cup wouldn't enter into my reproductive system, or some other remarkably unfortunate place!!!
I'll start collecting cups and stuff for the SIP.
May 7, 2010. 7:37 AMnutsandbolts_64 says:
 Oh no, I can't find the vote button! Nice project anyway. I'll be sure to make my shelves with those.
Apr 24, 2010. 7:44 AMKryptonite says:
You heard about that group that made a bridge span 5 metres, that held 200kg and was made of paddle pop sticks and glue?
Apr 27, 2010. 12:47 PMHiyadudez says:
Link?
Sep 17, 2010. 4:42 AMKryptonite says:
I've looked every where and haven't been ableto find it.
Apr 28, 2010. 3:45 AMKryptonite says:
It was on tv a few years back. Can't find a link, goddamn it!
Sep 14, 2010. 8:51 AMtulekah says:
there are annual competitions all over the country, and the world, for this. google popsicle bridge competition and you'll find all you want. the great ones are where, rather than unlimited sticks, the contest is to make the strongest bridge with a small number.
Some of the results are amazing.
Apr 25, 2010. 9:19 AMmrmarshall1 says:
this sort of thing could be used to make walls for houses. it would be strong, light and thermally insualating thanks to the small pockets of air in the cups would provide..good job!
Apr 23, 2010. 7:25 PMbucklipe says:
Another aspect to gluing up the project would be to paint on a layer of glue to the boards and let them dry or at least get tacky. This seals the surface so that new glue will adhere better. Do the same with the rims and bottoms of the cups. If you choose to let them dry, reapply glue to the rim and bottom of the cups and assemble and compress it. If you can reassemble it while tacky (not likely), compress it. Re-test the strength after this...
Apr 22, 2010. 5:23 AMwilmadan says:
great idea! i think this will be helpful in building a house by filling up the cups with earth and the cups will serve as the blocks.use chicken wires to make it sturdy
Apr 18, 2010. 3:00 PMKiteman says:
This could make an interesting door or screen-wall, especially if you use transparent acrylic to sandwich the cups.
For a table-top, you would only need the top surface to be transparent.
Well done.
Apr 19, 2010. 12:18 PMknektek says:
Yes, if you want to look like a poor man who can't afford a proper table. Instead he would have a table made out of coffee cups.
Apr 20, 2010. 4:24 PMToastalicious says:
you underestimate art
Apr 19, 2010. 12:30 PMKiteman says:
I guarantee that if you made a table like this, and sold it through an agent, you would get well over the price of a standard table.
Apr 23, 2010. 11:16 AMknektek says:
it is now futile for me to emphasise the words 'coffee cups' ...
Apr 27, 2010. 12:52 PMHiyadudez says:
It may be cheap, it may seem tacky to you, but to others, it is a work of art, and a sense of taste, which apparently, you don't have.
WORD.
Apr 27, 2010. 1:38 PMknektek says:
This is a world with opinions. Anyway I was talking about using USED CUPS for this. Not ones that have been drank from. Other than that this is a great project.
Apr 28, 2010. 12:17 AMHiyadudez says:
You didn't say USED CUPS once in all of those comments, so don't play that with me.
Apr 28, 2010. 10:59 AMknektek says:
Well, i'm not playing anything with you. so...
WORD!
Apr 28, 2010. 11:06 AMHiyadudez says:
Word.
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:bertus52x11
Check out The CameraClip, a commercial spin-off of one of my I'bles at www.cameraclip.eu OR in the Instructables Store!
