3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee Cup Sound Proofing
  Sound proofing is a foam material shaped with holes or waves in the exterior this absorbs or deflects sound waves.
   This will show you how to do the same with old coffee cups.
 Here's what you need, Coffee Cups A LOT of them about 16 per foot of wall.
But these are easily found where ever hot beverages are served. (or the garbage can next to that place).  Or ask the owner if you can set up a box for recycling them.
 Coffee cups are mostly made from  polystyrene and in my opinion is a horrible compound and should be eliminated all together.
  The only way to do this is to recycle it until the point that it is no longer possible to produce profit from it.
  And a adhesive, you can use just about any kind, spray glue, hot glue, wallpaper adhesive  but i find that great stuff spray in foam insulation works the best for this project. You'll need about 8 -10 for a whole room or basement.
Step 1Step One: Remove Wall or Add a Second One
 im just using a plywood board for example on how to lay the cups out.
  But works well in empty wall spaces, or as i did for a friend a layer of foam cups and carpet covered plywood did a amazing job, he can now use his basement to practice with his very heavy metal band with out disturbing his neighbors.
    Also filled ceiling in basement with cups the sound was reduced at least in half from the basement to the first floor.
   P.S Your wall space may be thinner then the height of the cups , so you can just cut them down.
30 comments
Mar 1, 2012. 12:28 AMuhsnamih says:
I wrote an instructable about sound proofiung your room last year. Give it look, its easy and a little different method.
http://www.instructables.com/id/Super-Soundproof-Your-Room-Poor-Mans-Anechoic-Cha/
Apr 25, 2010. 8:46 AMeblisster says:
I don't know whether or not this would work for sound proofing or insulation;  I'm more concerned about how flammable it would be. Seriously, this sounds like a conflagration waiting to happen!
Apr 20, 2011. 8:18 PMspacker says:
Ten points for the use of the word 'conflagration' in a legitimate sentence!
Mar 18, 2011. 9:32 AMjvet says:
For sound absorbion , middle tone ( not all ofcourse )
the best " cheap " solution is to use cardboard egg containers , !.
you need allot less of them, and behind them, stone whool
for bass you coud better use a flat surface , like wood or glass,
midd and bass, layers of cardboard, and carpet ,
Hang them onto wood free from the wall and floors so they can vibrate on there own.
but the easyest way is to use , heavy curtains ! ( all the way to the ground , )
think about the garage door ! there often flat and thin ,
so you need to combine the cheaper solutions ! ( als for professionals sound proofing you need diferent types of foam and forms! .)
Aug 25, 2010. 11:16 AMareyouserial says:
I built a music recording studio in a commercial location with neighbors so we had to ensure complete sound-proofing. We achieved it through the use of fiberglass insulated staggered-wall construction, two layers of carpet padding under the floating wood floors, wood floors that didn't touch the walls with the perimeter sealed with silicone and a drop ceiling with six inches of fiberglass insulation.
May 6, 2010. 7:12 AMMatrixDweller says:
One problem...styrofoam cups and great stuff make for some pretty toxic smoke in the case of a fire. Building codes state that styrofoam must be covered so inwall might be ok, but onwall is not. It's most likely against building codes to fill a wall with cups and expanding foam.
Filling  wall cavity with anything will help with sound proofing. Using cups and great stuff might not be economical though as the great stuff gets expensive. Figure a batt of insulation might be $4 per wall cavity. To soundproof you need to do two things, add mass (lots of it) and seal up the room air tight. The great stuff will helf you accomplish #2 but not #1.
As for this as an acoustical treatment, closed cell foam is not very effective as an absorber and great-stuff is not very absorbant either. You need rigid mineral wool or fiberglass boards. Your construct would be more of a reflector.
Apr 25, 2010. 10:19 AMcreep144 says:
 The truth of it all is that it doesn't matter what you use inside the wall. It's not what you use, it's what you don't use. By that I mean that the dead air space is the only thing that stops the transfer of sound through the wall.
Apr 19, 2010. 5:41 PMyanksguy says:
I'll call your bluff.  Name and address please.  Also, to be fair, you need to measure decibel levels pre-foam cup and then post-foam cup.  Have Ipecec play a couple of songs (set to 11 on the amp) before and then after.  Purchase a sound level meter (http://www.amazon.com/Extech-407730-130-Decibel-Digital-Sound/dp/B000EWY67W) and check.
It's not that I don't think that you did it, but that the sound insulating efficiency of foam cups is not enough to do what you say it did.  Maybe the neighbors were freaked about the neighbor who had 40,000 hot chocolate encrusted foam cups that were piling up around the garage, and figured that earplugs might be the wiser option than upsetting the crazy next door.  Not that you are crazy.  No, I'm not saying that.  There are other variables involved here, that's all I'm saying.
Apr 22, 2010. 2:58 PMmakerboy112 says:
Your suppossed to use drink carriers for soundproofing.
Apr 21, 2010. 8:51 PMStrangeRover says:
... but clever and eye-catching it is!
Apr 21, 2010. 8:50 PMStrangeRover says:
Sorry to say, anyone who know a few things about sound knows the difference between acoustic treatment (egg crate foam; this project; pyramid foam; etc) and soundproofing, which is meant to stop sound from entering or exiting a room or building.   This one definitely should be called acoustic treatment rather than soundproofing.
And how anyone can stand to drink from those Styrofoam cups is beyond me...
Apr 15, 2010. 12:19 PMDuckism says:
regardless if it works or not... if you read the instruction on the contest it says using "paper" coffee cup, but you are using foam here....
Apr 18, 2010. 1:36 AMKryptonite says:
You could probably do both.
Apr 18, 2010. 2:38 PMDuckism says:
don't know... but the words "paper coffee cup" surely showed up quite a few times on the contest
Apr 20, 2010. 5:06 AMKryptonite says:
Fair enough. Paper coffee cups would still work for this, and I think that's the main thing they're looking for, if they're looking for any difference at all.
Apr 19, 2010. 5:25 PMyanksguy says:
Better wall insulation reusing materials:1)  pull up local Craigslist on your computer; 2) search "insulation"; 3) go pick up free or cheap insulation; 4) put it in your walls.  What to do with all of those thousands of foam cups?  Recycle: http://www.dartcontainer.com/web/environ.nsf/files/M-343.pdf/$FILE/M-343.pdf
It was a nice thought though.  Probably the carpet did more than the cups did.  Now if you could fill that space with packing peanuts then it might work.
Apr 18, 2010. 8:35 AMMrSalvador says:
if he didnt want t odo it himself( obviously he didnt do a wall ) then why would you expect other people to do it?
Apr 14, 2010. 3:05 AMcraig3 says:
If your basing this off of eg cartons then it wont do anything, egg cartons are good for holding eggs and making caterpillars, they do almost nothing for sound proofing.
Have yo tested this out yet?
Apr 14, 2010. 9:09 PMcraig3 says:
what ever, main point is its sound blocking quality, or lack of
Apr 13, 2010. 5:50 PMJakeTobak says:
Did you actually do this? I can't imagine Great Stuff working that well as glue.
Apr 13, 2010. 11:07 AMlemonie says:
The cups need to be paper and you need to actually do it for the competition.
L
Apr 13, 2010. 10:41 AMtheRIAA says:
I don't think this would work.. at all.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
67
Author:MadMan.inc(Canfield Farms)
I am currently taking over my grandparents farm, and working towards getting off the grid, and a sustainable life.
