3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee Table (Hack of IKEA LACK)
Step 4Mount Table Legs
Mount Table Legs
  • last photo ←
In this step we will cut the pipe legs and mount them to the bottom of the table to form the pipe base.
3.1  Screw flanges to the bottom of the table top. I just eyed the distance from the edge because I was mounting the flanges so close to the edge.
3.2.  Cut table legs to desired length. I used the old table legs from the IKEA coffee table to determine the leg height.
3.3  Insert table legs into the flanges that have been attached to the bottom of the table.
3.4  Measure the distance between the end pipes and cut the pipe to that length to form the brace ends.
3.5  Slip on a tee fitting onto the brace pipe that was just cut and then put a tee fitting on either end. At this point you should be able to slide that piece down onto the two legs at the end of the table.
3.6  Once both the side braces are on, measure the distance from brace to brace. This will give you the length of the pipe that runs down the middle of the table.
3.7  Once you cut the middle runner pipe then month the pipe between the two middle tee fittings to complete the leg bracing.
3.8  At this point you can begin to tighten your fittings. You may want to wait to do your final adjustment until after the table is flipped over.
3.9  Insert end caps. The end caps I used were designed for use with schedule 40 pipe, not aluminum fence post, so you will need to apply a bit of epoxy or glue to the end caps before inserting them.
3.10  At this point you can flip the table over and do your final adjustments.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
64
Author:simplifiedbuilding(Simplified Building)
I own a online business that sells industrial pipe fittings (Kee Klamp), PVC (pipe and fittings), as well as unique projects made with these products.
