This is one of the very few designs that I have actually built, and the one I am most satisfied with both design wise and construction wise. To say I was surprised that I could build it (and do it well) would be a bit of an understatement. What surprised me most were the very basic tools I could have built this with. I cheated a bit and used a CNC for part of it, but it really isn't necessary. All you really need is a jig saw, drill, router and a few hand tools.
This instructable is split into two main parts, design and construction. The design section is brief and more of an explanation of how the concept came about than an attempt to describe the design process.
For more pictures of the finished coffee table see the slideshow: http://www.instructables.com/id/Coffee-Table-Mackintosh-Inspired/
Remove these ads by
Signing UpStep 1Design
I chose Charles Rennie Mackintosh for no particular reason at all. Dont even like the Glasgow style all that much though I have a much greater appreciation of it now after studying it a bit. Lucky for me I happened to find myself in Scotland for a few days mid-semester and got to visit the magnificent Willow Tea Rooms and take in a bit of the atmosphere, have some tea and take a few pictures.
When I got back home I wrote a personal brief to guide me ("Create a piece that evokes the modern atmosphere of a social gathering. Much like the atmosphere of The Willow Tea rooms in CRM's time") and started drawing Mackintosh decorative motifs to see if I could get some inspiration. I didn't want to try and sample directly by creating a piece that looked as if CRM himself had designed it because the style doesn't appeal to me, and the table was after all for me. So I looked at all the elements that appear again and again in his work, sketched them and tried to extrapolate out of them something out of scale with the original.
At that stage my personal brief and those little motifs converged and screamed at me to make a coffee table to bring people together. So to make this long story short this design as born.
Some of the models and the full scale mock up are pictured. Originally I wanted to have the sides/legs perpendicular to the ground but I realised that no one would be able to sit up to it if that was the case. These models were as important as the CAD models for refining the design.
If I was going to make this again I would make it slightly smaller for better usage of materials. I could cut the amount of 6mm MDF needed in half with a simple design change.
Never would've thought of laminating MDF into an arc, good show. However MDF is more susceptible to moisture than just about anything else. My concern is, being a coffee table, it's intended to hold drinks which will sweat if of the cold variety... Maybe not a problem though depending on the lacquer, I'm not that familiar with the properties of lacquer as a moisture barrier.
For those unfamiliar, bending plywood is 2 ply plywood with one ply substantially thicker than the other, it is usually described dimensionally as 8'X4' or 4'X8" depending on which way it bends, long way or short way. The grain of the thicker lamination runs perpendicular to the direction it is to be bent, meaning that the grain will go straight the full length of a cylinder, the grain of the thinner lamination goes with the bend, so it would follow the circumference of a cylinder meeting it's own end grain to complete the cylinder.
http://en.wikipedia.org/wiki/Charles_Rennie_Mackintosh
oh and i hope it got you a good grade =P
