Step 9Angle Jig 2
Make up some sides about 500mm high and perpendicular to your bench or whatever you screw them to. Screw the already angled edge of the leg to a base and slide it in. Mount the router as shown. Rout away until you have the leg to the finished height.
Angles all done, both legs should be the same height because you didn't change your router plunge depth between cuts.
Again with this one I had to get the electric planer at it a little to get it down to size. I should say that you could probably mark and cut that off witrh the jig saw, but I am lazy and didn't think of it until I had everything set up.
Add Comment
