3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee Table with Antique Windows
My mother wanted a unique, traditional and modern coffee table. I found some old antique wooden windows at a flea market, and designed this coffee table around them.
Step 1Windows
Windows
I found windows, like the one pictured, at a flea market for $3 a piece. I bought three. These are what the table was designed around.
23 comments
Mar 13, 2012. 3:57 PMLoopstyle says:
Amazing work! If you want to be more inspired visit our webpage: www.loopstyle.se and you are more then welcome to post a Loop :)
Thanks for the inspiration!
Mar 25, 2010. 11:13 AMcogni says:
Looks very sharp! I think it would be hard to find antique double-paned windows in the U.S.; old windows with the glass still in probably would not have strong enough glass. But another possibility is to use EMPTY frames (I have some from some antique window screens that I pulled the screening out of--they look very much like your window frame) and sandwich the frame between sheets of table glass, with small objects mounted on the lower surface.
Feb 12, 2010. 3:55 PMjestrada9 says:
This is pretty cool!  first thing I thought of was to put a board maybe 6" below the windows and then you could put flowers, knickknacks, etc in between.
Jun 10, 2009. 6:08 AMheathbar64 says:
Great Idea!! How is the glass? it would seem to me that old timey window glass would be too fragile for a table. Also, is it secure enough in the frame? most old windows are just held in with a few tiny glaziers points and putty.
Jul 21, 2009. 10:08 PMgot2bskilled says:
Wonderful piece! I am certainly inspired to try and make one!
Jul 20, 2009. 6:09 PMIvriniel says:
It's lovely.
However, CBC Marketplace recently did a story about injuries from tables made from non-tempered glass. They said that 20 000 people in the US every year are injured falling through glass tables.
http://www.cbc.ca/consumer/story/2009/06/26/f-johnson-glass-tables.html
Just something to consider if you're going to do this project.
Jun 1, 2009. 4:37 PMdindanpacman says:
You could even put some plywood under the glass, which should stop the glass from breaking. In between the glass and plywood you can put pictures.
May 25, 2009. 4:44 AMand7barton says:
Personally, I would put a sheet of glass right over the top, but removable. Then one could place objects in between that and the smaller panes, like rocks & crystals, or any collection of objects that you'd like to display.
May 23, 2009. 7:24 PMthebriguy says:
I'd use real glass not plexiglass. Plexi scratches and you need to be more careful cleaning it. Regular glass table glass or the type you put on top of a dresser would be best.
May 22, 2009. 1:33 AMomnibot says:
Very nice. Did you keep the original glass in them? I know ordinary windowglass is prone to break when weight is applied.
May 22, 2009. 8:12 AMTubehacker01 says:
I see the same problem, for optimal result, you should use some type of acrylic glass.
May 22, 2009. 6:54 PMjaysbob says:
another easy solution would be to put a sheet of acrylic or glass over the entire top of the coffee table. this would also give a more level and easy to clean surface for the whole thing without significantly changing the aesthetics.
May 22, 2009. 9:05 PMartquilter says:
The instructable is very nice and did a fab job with the windows, and I really like the idea. Each window could be a different color to match decor, lots of ideas could come of this. I think I would make the sides 1/4" above the windows and lay a piece of plexiglas over the whole thing...then no difficult cleaning each pane, no worrying about breakage, etc.
May 22, 2009. 9:07 PMartquilter says:
Forgot to add: Good for old stain glass windows too
May 23, 2009. 8:30 AMachollowell says:
very good job I like the idea
May 23, 2009. 6:08 AMG.O. Bluth says:
Looks Great. I would just makes sure the glazing and points (Small, metal pieces that secure glass to frame) are in good shape, as the window is mounted with the glazing down.
May 21, 2009. 5:58 PMMr. Rig It says:
I like this a lot! Great job!
May 21, 2009. 4:37 PMMeganTManey says:
The table is beautiful.
May 18, 2009. 12:09 PMPkranger88 says:
Very nice
May 17, 2009. 9:49 AMarte.sano says:
neat, great stuff, I've contemplating this idea but with an old door with boards to make a dinning table. very well done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:TimBTodd(Tim Todd)
