Coffee Table
Introduction: Coffee Table
Hey everyone!
I wanted a small coffee table to be in my living room So i went a head and built one!
Enjoy !
Step 1: Mix Cement and Sand in a Box
Take two cement packs and half a kilo of sand and mix it together with water
Step 2: Create the Pole
I have bought 4 poles ( was long one but i cut it )
Made sure it`s the same height, and attached them all to some bas ei build ( from wood )
Step 3: Drown It !
Once you finished mixing the mixture of sand , water , and cement
" Drown " the base of the legs and make sure it sitting good
Step 4: Check With Leveler
Make sure it`s the same height
Let it dry for 12 hours and then poor 1/2 a liter of water to the cement - it will obserb in it - that way the cement will be stronger
Step 5: After Two Days
Seems good
Step 6: Remove the Plastic Box
Slowly remove the plastic box from the table
Clean the sides and remove leftovers
Step 7: Paint the Legs
Choose some random color, and paint the legs
Use a duck tape to mark the exact place fo
Step 8: Remove the Duck Tape
Step 9: Paint It!
i painted it , 3 layers
Let it dry between one layer and the other
Step 10: Padding
Add beneath the legs some padding , for it to move easy
Step 11: Done!
It was a fun quick project!
Let me know what you think
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    "Hey honey, I'm gonna bake some cakes.... have you seen the whisk" "erm......" amazing how many kitchen things work great in the workshop!
    so simple and elegant! love it! was the plastic bin difficult to remove? in the photo it looks like some chips came off?
    Thanks for the comment , it was very easy to remove, thought it would stick to it , but all i had to do was shake it a bit , and it removed almost perfectly
    Yes, a few chips broke , but it`s very easy to fix, since all you need to do is make a bit more cement mix , apply it , let it dry , sand it , and your` done
