Coffee Cup Sleeves
1,086
5
Published
Introduction: Coffee Cup Sleeves
About: Music is my main hobby. I like making things in general and dismantling and remantling everything. I like to know how things work.
How to make those sleeves that you find at some cafes that keep your fingers from getting too hot, out of a used coffee cup
Step 1: Roll the Lip
Roll back the top edge of the cup with your thumb until it is flat. Just put the tip of your thumb below the lip and slide backwards.
Step 2: Continue Rolling
Until it looks like this:
Step 3: Insert Finger
Between the cup and the sleeve, there is a gap. Push your finger in here to separate the cup and the outer sleeve.
Step 4: Dislodge Adhesive
Slide your finger all the way around the cup until it is pretty much separated. There should be a line of glue down one side of it, don't worry if it gets slightly ripped.
Step 5: Push Cup Out
Put the base of your hand at the bottom of the cup and slide your fingers down the side. It will resist for a moment, but you should soon be able to slide it off.
Step 6: Finished!
You now have a sleeve that will keep your fingers cool, or by cutting a handle will allow you to  carry drinks without burned digits!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    5 Comments
    Dude! Coffee, when it is made to the correct standard, is delicious
    Ha! I thought you were saying OK to Pie! I will always say "Kai" to pie.
    Pie is always OK
