3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee cup sphere lamp
Step 4Placing the lamp
placing the lamp
  • last photo ←
So now you take the last cup, heat up your scriber and burn a hole in the bottom. Place the big washer under the underside, tie a knot in the electrical wire and put it through the hole from the outside. Attach it with the split bolts trough some holes (which you'll have to meld with the scriber first off course) with the small washers in between to prevent them slipping through. Now you can easily remove the cup if the lamp is broken.
Never mind the paper clips you see on the photos before, those where a first try to fix the last cup in place: It didn't work.
Your lamp is finished (only have to hang it on the ceiling and put the wires on the electricity off course. Be careful with that!).
Let it burn!
7 comments
Aug 24, 2011. 4:57 PMgzech says:
How many cups did you use? 300?
Jul 18, 2010. 8:42 PMkylek says:
it would look really cool if you put different colors in the bottoms of each cup some how. maybe like plastic disks or even clear cups painted with semi translucent paint.
May 13, 2010. 1:52 PMcoolboy45 says:
do you think this could be fitted onto a normal table lamp?
May 13, 2010. 11:55 AMrbormann says:
When I was much younger, I made one of this but I used glue, not staples and it worked very well, the cups never got loose.
The only difference in my construction is that I started by making the middle  circle, and went building the ball.
May 13, 2010. 7:18 PMrbormann says:
You're right. Glue has it's own setting time and I also can't wait to see it built, he, he, he...
The only advantage in building it from the middle is that you can fix the socket with more ease and if you have someone to help you, you both can work it out in the half of the time!
Greetings
May 9, 2010. 9:23 PMsfcsarah says:
does it get hot? Is it dangerous?
May 10, 2010. 8:33 AMteapotking says:
 Better still, you could buy (or make, they're not too difficult) one of those energy efficient L.E.D arrays! It would put out very little if any heat, it's brighter than a light bulb and It uses less energy than even the energy saving bulbs. you just wire them up to the cable that comes out of the ceiling and leave it hanging inside the chandelier, because normally they are actually mounted sunk into the ceiling.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:Aeolus(Dave Akkerman)
I´m a teacher in arts and crafts in a secondary school. I love to make things. Especially out of nothing, worthless materials, garbage and cheap stuff.
