3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coffee table upgrade!
Step 9The Final Product..
The Final Product..
Bah! I took a break during the middle of this project (In fact, we got a new cooker, fridge and rangehood, so I butchered the kitchen benches apart to fit those in - perhaps a story for another day)
..but the table is is finally done and we love it.
End result..
Closed, the table is lower than it was.. like a regular coffee table. At the end of the day when you put your feet up, it is relaxing - not uncomfortable.
Open, and sitting at the table on the couch, it is a little higher than a standard table would be if you sat down to it on a chair, but it is great.
We have the extra storage and can sit up to it quite comfortably to eat.
Changes I would make..
I would definitely measure the overall open height against the couch seat if I was going to do it again. A tad lower would be slightly more practical.
9 comments
Apr 9, 2010. 9:02 PMoffseid says:
Hey thanks for posting this. I especially appreciate your DIY hinges, since the setup most people use (from Lee Valley) costs $160! I do have one question about the hinges. Okay, maybe two.
1. So the hinges butting up against the table is basically how you determine how far the table comes towards you, right?
2. Have you seen any wear and tear on your hinges as they keep banging up against the table top? Are they getting dented up? I suppose you could file away the inside of the table top right where the hinge meets the table, so it meets a flat surface instead of a corner.
Anyway, I'd appreciate your thoughts!
Dec 7, 2010. 1:17 PMbigjeff5 says:
If you are worried about wear and tear you could always attach a wedge-shaped block of wood just in front of where the lever connects to the bottom support rail, where the angle of the wedge is the exact angle of the lever arms just before they hit the edge of the box.  This will catch and support the rails instead of the front edge of the table.
You just have to be sure it isn't taller than the two rails when closed, and that it won't get in the path of the top rail as it is coming down.  As a bonus if you put four of these in (one for each rail) and you measured everything just right it would add a lot of stability to the top when opened.
Sep 24, 2010. 8:17 AMjscott119 says:
just saw this instructable and wanted to say it is a great idea, i plan on using the DIT hinges in the coffee table I'm going to build. You saved me $160 buck by not buyin gthe specialty hardware instead, so thanks.
Apr 11, 2010. 7:21 AMebrperk1 says:
 Great Idea, the finished product looks really good. This instructable will definitely be copied several times
Again Great Job
Feb 27, 2010. 7:23 AModelagarza says:
excellent job!!!, I love this instructable
Feb 20, 2009. 3:24 PMAnneKoneska says:
I saw a table just like this on sale at a franchise furniture store and they wanted nearly 2 grand for it (USD)!!! This is a very good alternative if you have even a little know how! Good job!
Jan 4, 2009. 7:58 PMaristocob says:
Well done. We have a table that I've been considering doing just this exact hack to for some time. My wife better not see this.
Dec 20, 2008. 4:57 AMrageklpxjock says:
Genius!
Dec 18, 2008. 12:42 PMQuinnRenaud says:
I love these tables. My bother has one, but it's a little different. It has an open bottom, instead of a drawer, but still has the "top" under the Pull-out top. It's the coolest thing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:lofgren
