3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coilgun Handgun
Step 3Coils, Capacitors, and Results
All measurement are taken from velocity test with chronograph and are maximum achieved.
22 gauge:
-UM:7 Layer, 33mm L, 6.5mm InDia 1320uF 330V E.37m/s 4g(11*330V 120uF)
-8 Layer, 30mm L, 8mm InDia 960uF 350V 24m/s 8g(8*330V 120uF) 3.9%
-12 Layer, 30mm L, 8mm InDia 600uF 350V 12m/s 8g(5*330V 120uF) 1.57%
-12 Layer, 30mm L, 8mm InDia 470uF 450V 27m/s 8g(1*400V 470uF) 6.1%
-16 Layer, 30mm L, 8mm InDia 470uF 450V 28m/s 8g(1*400V 470uF) ****Best results 6.6%
-UM:12 Layer, 30mm L, 8mm InDia 470uF 800V E.>50m/s 8g(4*400V 470uF)
20 gauge:
-UM:12 Layer, 29mm L, 8mm InDia 940uF 400V 31m/s 8g(2*400V 470uf)
-UM:12 Layer, 12mm L, 8mm InDia 1200uF 350V 26m/s 8g(10*330V 120uf)
-8 Layer, 12mm L, 8mm InDia 880uF 450V 13m/s 9.0g(4*400V 220uF)
-Ferrite Surrounded-8 Layer, 12mm L, 8mm InDia 880uF 450V 14m/s 9.0g(4*400V 220uF)
-8 Layer, 30mm L, 8mm InDia 1100uF 450V 33.0m/s 9.0g(5*400V 220uF) SCR Switched 4.4%
E.=Estimated Velocity-The velocity here is estimated based on visual comparison to the other results, they are Not measured.
UM=Unmaximized- Coil not experimented with to achieve maximum results
If you do not have access to a chronograph the method HERE is relatively accurate.
If you use this method to get velocity results make sure your coil is perfectly horizontal and don't fire to the ground, fire at a piece of foam that is a meter or so away.
Also HERE is an optical velocity measurement set up. I have not done it my self so I do not know how accurate it is.
Even at best the shown results are + or - 20% correct, this is because most electrolytic capacitors capacitance rating is within the + or - 20% region. In order to get the results above you may have to test several different capacitors to match whatever value mine might have actually been.
My projectiles and speed measurements are close to 100% accurate so + or - 20% is the maximum offset.
20 comments
Jan 31, 2010. 10:39 AMhunter566 says:
can i use 220uF 400V capacitors and still  get enought power to shoot omething a couple feet away
Jan 31, 2010. 3:56 PMeggman says:
 absolutely.  throw a few of those in parallel, and you've got yourself a formidable coilgun.  depending on whats available to you, i'd aim for 5 or 6 of those capacitors in parallel.
Feb 2, 2010. 3:23 PMhunter566 says:
if i used 7 how many cameras do you think i would need
Feb 2, 2010. 8:11 PMeggman says:
 that puts you at 1540uF  i would use 6 or 7 chargers running on 4 D batteries at 3V.
Nov 24, 2010. 8:44 AMJduhl says:
4 D batteries would put you at 6 volts
Jan 8, 2011. 2:57 PMTehMessiah says:
erm.... no... if in series it would, but in a hybrid of both this is how i'd look
|- + 3vdc, so then it has twice the power of a 3vdc in series :D lol this is an old comment but still...
Nov 24, 2010. 11:42 AMeggman says:
2 batteries in series gives 3V. connected in parallel to two more in series stays at 3V but doubles the amperage.
Mar 10, 2010. 3:56 PMmagiccowy says:
What about the really big 400v caps you can get out of computer power boxes. How many would i need for the same power as him. Thanks
Mar 10, 2010. 4:53 PMeggman says:
 well his caps probably came from a computer PSU, along with yours.  i have a few 400V 220uF caps that came from PSU's.  if yours have a different capacitance, let me know.   otherwise, you'll probably have about the same power.
Mar 11, 2010. 4:57 PMmagiccowy says:
Thanks what would be the best cap to use and how many chargers would i need
Mar 11, 2010. 7:04 PMeggman says:
 use whatever caps you have with the EXACT same voltage rating to add up to 1000-1500uF.  same amount of chargers.
Mar 14, 2010. 5:12 AMmagiccowy says:
Thank you
Dec 7, 2010. 2:42 PMGakkenGod says:
If i may ask your opinionI have capacitors ranging from 6800uf 75V to 22uf 250 volts as well as various smaller ones.... what capacitors uf number and volt number should i use? I have read your instructable on this matter and cannot figure out what capacitors i should use. Thank you,
Dec 7, 2010. 8:40 PMeggman says:
the comments almost have more info than the instructable. you need at least 330V. the capacitance ranges but a good start is 1000uF per stage.
Jun 26, 2010. 7:24 AMzattifier says:
I need some help with charging circuit theory. I have built a decent coilgun whic doesn't actually shoot THAT far. With 1.3V (drained 1.5V) it will make a dent in the side of a tissue box and with the extra 0.1V (1.4V) it will nearly break through. I wanted to know if I could regulate a 2V into the charging circuit, which would charge the capacitors at about 360-380V (they are rated at 400V). Also, I would like to know if I could use multiple charging circuits, so as not to destroy the capacitors by feeding to much voltage, but to decrease charging time, thanks guys.
May 12, 2010. 5:28 PMhunter566 says:
I need some help Im confused on how to wind the coil because i dont no if i should finish a coil then cut it then start a new layer or just go back and forth
May 13, 2010. 3:51 PMmoshee says:
 Back and forth.
Jan 15, 2010. 3:26 PMtim.vrakas says:
I have some old NP1 12v batterys how do i make them work
Jan 8, 2010. 7:13 PMMilesla says:
This is probly the sweetest thing ive ever seen
Nov 16, 2009. 2:44 PMalvaromanuel says:
could you please tell me the diameter of the wire(not in Gauge)
Sep 26, 2009. 10:26 PMkrooq says:
So how do you have your batteries wired? like my pic-? and whats the max voltage for the kodak circuts? also what is the point of having more batteries with one circuit, it would do nothing is they were all at 1.5V right ? i live in australia and it is near impossible to find used dispossable cameras, damn digital and noone sells capacitors here. how much are your DC to HV convertors it looks a bit difficult to make
Sep 29, 2009. 3:14 PMmoshee says:
that last bit of wire on the left side is not needed (actually it creates a short circuit). kodak circuits output 500v from 3v i think, more batteries in parallel gives more capacity (longer battery life). capacitors are available online (farnell seems to be popular down there) and the charger circuits on http://futureexperimentalsystems.googlepages.com/productsandservices are $75
Nov 16, 2009. 2:42 PMalvaromanuel says:
400v from 3 v
(that's rwilsford's website)
Sep 25, 2009. 6:29 AMkrooq says:
What did you use to charge this one? 16 Layer, 30mm L, 8mm InDia 470uF 450V 28m/s 8g(1*400V 470uF) ****Best results 6.6%
Jul 6, 2009. 10:07 AMplaneboy95 says:
will the uF be shown on the capacitor? and how do you get 330V out of a battery
Jul 7, 2009. 6:39 PMjondo huang says:
the capacitance rating is usually labeled on all electrolytic capacitors. In order to make 1.5 v from a battery become 300+ volts you must use a voltage amplifier circuit involving a 'step up' voltage transformer.
Jul 5, 2009. 7:36 PMplaneboy95 says:
i dont get the chart above. how do i make the projectile go the fastest
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
183
Author:rwilsford07(Future Experimental Systems)
