Step 4Bring It All Together
Test the system, if it works use Plexiglas, wood, or even metal to make housing for your gun depending on the desired size/weight etc.
Let Me Know If you I can Improve this page.
The Battery Banks Must not exceed +3V for safe operation.
Also, you "really" only need one charger circuit, as they can provide enough voltage, however, the more the merrier (to a point!), as they would charge your caps faster. one charger for 12 of those caps would take quite a while to charge. just try it with say... 12? you can always add more chargers.
for the relay, you would probably have to get a better one, but it depends on your voltage, and amperage. you can just find one for over however many volts you use, and for a high number of amps - maybe 50? This would be important, as you don't want your relay to fuse!
Let me know if you have any more questions :D
open up the kodak ones, and look for a similar charger to the ones in the pictures. it's kind of a blueish green, and you can tell it's right because the pinouts for the parts you cut out are correct.
Whats the point of D1?....is it to make sure the current will always flow one way?...or does it prevent "suck back"?
My question is either how would you wire that switch or could if I just resort to my good ole friend SPST? Much appreciated
If i wanted to add a light to the circuit to show when its charging/charged. Where would i connect it too?
ATM i have:
batt pack >> switch >> charger circuit >> caps
In that sequence where would i add it? WOuld it operate like the light on cameras where it flashes to indicate charging and solid to indicate charged?
http://sites.google.com/site/futureexperimentalsystems/pa-3
Someone told me putting an LED just after the caps on a resistor would work?
or you could attach some sort of comparator to the caps/ground, and hook that up to an LED
i would appriciate it if you could include instructions for modding a camra circut with only 4 lead wires to the transformers
