Introduction: Coin Pouch for Mighty Wallet
Picture of Coin Pouch for Mighty Wallet
Recently I bought myself a mighty wallet since I liked the idea of a nice thin alternative for my conventional leather wallet. However, I live in Europe and you really need a coin pouch around here here. Firstly I was a bit annoyed that they don't offer one with such a feature. But than, I found out that its easy to built one using just the packaging that came with it. Since the hanger is also made from Tyvek, it should be just as durable as the rest of the wallet.
Step 1:
Picture of
At first cut off the hanger as a template. Because the hanger just happens to be slightly narrower than the wallet, It will allow to fit the pouch snugly in one of the side openings of the wallet.
Step 2:
Picture of
Use the template to mark the desired width of the pouch. Starting from the lower end of the text block.
Step 3:
Picture of
Fold it at this marks and flip it over.
Step 4:
Picture of
Attach some adhesive film at the end of the ribbon at the blank side.
Step 5:
Picture of
Form the pouch and secure it using the adhesive film at its inside.
Step 6:
Picture of
Flip it over and fold the rest of it under a 45° angle.
Step 7:
Picture of
You want to be sure that this fold is firm, than apply some adhesive film over the two holes by the hanger.
Step 8:
Picture of
Flip it over again and use the adhesive covered holes to stick this side to the back of the pouch. If you've done it right, the pouch is now closed form 3 sides.
Step 9:
Picture of
Flip it over and use the rest of the sheet to form a flap. I've decided to stay with a rectangular shape and 2 layers of material.
Step 10:
Picture of
Apply some glue to the flap and glue it in place.
Step 11:
Picture of
Now your coin pouch is finished. Not actually an eye catcher but it will do the job.
Step 12:
Picture of
Insert the pouch in the side-opening of your wallet and fill it with coins.
Step 13:
Picture of
Close the flap and you are good to go.
mkambas (author)2015-07-05
that's a smart instructable there, thank youj much. as you said, wallets with a compartment for coins are hard to find nowadays.
i had to make mine from strong plastic sheets, and sealed the edges with a FoodSaver (R).
you have plenty of options to seal/fuse plastics: using an electric iron, a styrofoam cutter, a length of straight rigid wire (heated over a candle flam) and so on.
seac (author)2014-06-19
wonderfull to see austrian currency again...
craftclarity (author)2014-06-18
Looks like a good way to manage those pesky monetary discs!
About This Instructable
8,705views
5favorites
License:
More by bertlds:Functional Mjölnir Prop - carpentry sectionArt Noveau for the 21th centuryWindow blind with forced ventilation
Add instructable to:
