3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Coke Bottle Oil Lamp
This is my first instructable. I bought a pack of the 1899 style coke bottles from the store and decided to recycle the 6 bottles into better things instead of just putting them in the bin down the road.
My first bottle has become a lantern. This is how to make one too!
Step 1Drink
The fist step is to buy and drink some cokes. I suggest soda bottles because they are thicker than beer bottles. Mason jars would work as well if you have some around. When you remove the top try not to warp the cap too much.
26 comments
Jul 22, 2011. 3:27 PMl_skywalker says:
this looks cool and i plan to make it but what are you supposed to do when that end of the wick is done. the wick will eventually burn off the knot.are you supposed to pull up more parts of the wick by hand and tie another knot? pleas explain in detail what you do when that small end of the wick is burned off.
Jun 6, 2010. 9:59 PMartlover1884 says:
would just a string work for a wick?
May 18, 2011. 8:30 AMKelticpaddler says:
I'm afraid not...well, not very successfully.
You need wick string (which has been treated with Boric acid).
I hope that this helps.
Nov 18, 2010. 5:27 PMmattbomb says:
ya, stay away from the plastic stuff, an old cloth will work cut at the side were they sew the many layers of fabrics together cut that off and it will work, try your near by home hard wear there you might beable to find proper wich, a foot for like 99 cents or something, well good luck with the building
Apr 9, 2011. 1:30 AMgkong says:
I'm having trouble, I filled the whole thing with canola oil and it seems as if my wick is fully soaked. I light it nice flame, but after 5 mins it dies?
Mar 8, 2009. 3:56 PM16centerfield says:
mine barely burns for half a minute. why? i let the wick soak for like 15 minutes and its about 3ft long wick. i used tiki torch oil.
Mar 1, 2010. 8:48 PMxak7 says:
you should try taking the wick out and soaking the whole thing, then put it back in.  Make sure the wick is soaking up the oil very well.  You should never have to pull the wick up because only the oil should burn.
Jul 26, 2009. 11:09 AMsharlston says:
would vegetable oil work?
Mar 1, 2010. 8:41 PMxak7 says:
yes vegatable oil, or any cooking oil will work fine. I use canola oil in all of my oil lamps and it works fine.  It's cheaper too, lol.
Jul 27, 2009. 1:52 AMsharlston says:
what about extra virgin olive oil its the only stuff i got?
Mar 1, 2010. 8:42 PMxak7 says:
Yes that will work fine.
Jul 9, 2009. 2:41 PMlilpepsikraker says:
Cool. I made one from a 2008 holiday edition Coke bottle, I've never seen an 1899 style. Oh well, I have a cool retro graphic to look at. I used soybean oil (it reeks, next time I'm at the store I'll get a bottle of lamp oil) and an unraveled cotton ball. Also, I used filtered water, dunno if that made a difference. I cheaped out and filled it with only 2" of oil, didn't want to waste too much. When it burns, it makes a cool crackling noise because the oil is boiling (again, it's cooking oil). I light it with a butane lighter, as my Zippo will make me spill it; Zippo's have an "always-up" flame.
Jul 27, 2009. 1:53 AMsharlston says:
just thought i would tell you the upwards flame of a zippo is becuase of the chimney to make it go up simply pull the wick out more!!
May 14, 2009. 8:33 AMjdtwelve12 says:
Really nice Instructable. I wonder though about the stability of the lamp. Many oil lamps have broad bases to help avoid tipping over. Obviously a spilled oil lamp is a bit more of a concern than a spilled coke. Have you had any problems with your lamp's stability, and have you considered weighting the base in some way?
Mar 7, 2008. 9:53 PMpyro13 says:
Very nice. My favorite use for an old glass bottle is this.
Mar 7, 2008. 12:44 PMItsTheHobbs says:
Where did you get the bottles?
Mar 7, 2008. 4:10 PMHIGHVOLTAGE-Z says:
walmart or gas station is where i found mine
Mar 7, 2008. 12:04 AMimonsei says:
I made one some years ago. I didn't have that long a wick, so i filled some of the bottle with water in which i put some food colouring. The oil floats on top so it's available to the short wick. :)
Mar 6, 2008. 8:54 PMGorillazMiko says:
Wow, great job! It looks very nice, I wish I could make one of these in my room, amazingly done Instructable.
Mar 6, 2008. 8:55 PMGorillazMiko says:
A few more pictures would be better though.
Mar 6, 2008. 7:15 PMmeddler says:
Brenn10 summed up my thoughts perfectly on this post.
Mar 6, 2008. 7:13 PMkillerjackalope says:
Not a bad use of an old bottle, there's plenty of lamps here, more uses for the idea are good... More pictures would be nice, not bad first time...
Mar 6, 2008. 7:11 PMBrennn10 says:
Just a suggestion. This Instructable would be really awesome if it included more pictures of the steps. It looks like an awesome project none the less, but users like the visual learning feel as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Corvidae
