Coke Can Stirling engine by scraptopower
video Coke Can Stirling engine
Here's a coke can Stirling I made, I didn't work as well as I had hoped but it's a starting point! Somehow the flywheel ended up completely wonkey and the bearings keep falling out and it's not very well balanced but other than that its fine ;-) The cranks are made out of a bicycle spoke, I used the thread on the end to screw on the flywheel so it can be easily removed. The piston is graphite in a pyrex cylinder  The target is to build a 1W Stirling generator out of coke cans, a long way to go yet !
jonathanlee0 says: Nov 18, 2010. 4:45 PM
whats the flywheel made of?
David97 says: Jan 15, 2011. 2:14 PM
It looks like wood.
firedude20123 says: Aug 15, 2011. 1:02 PM
either that or a cork "coaster" or a couple of em glued together haha???? no idea lol
Blofish says: Aug 2, 2010. 9:30 AM
This is how we succeed, thru our failures! Thanks for sharing
SasquatchKid says: Jun 17, 2010. 3:36 PM
Nice machine what can you power with it?
egbertfitzwilly says: Jul 3, 2010. 9:25 PM
The Stirling was an early competitor with the internal combustion engine. The ICE won out because we had this readily available, cheap fuel.... The fundamental design scales up extremely one can power any number of devices. I believe the primary production application in the modern world is in some model airplanes which can benefit from the high RPMs.
SasquatchKid says: Jul 4, 2010. 3:57 AM
Great im an aviator
egbertfitzwilly says: Jun 14, 2010. 6:12 PM
I wish you would post an instructable to go along with this. By itself its not any better than viewing it on YouTube.
scraptopower (author) says: Jul 3, 2010. 10:00 AM
I don't have any intentions of posting an instructable as it requires a graphite piston and cylinder which isn't easily available anywhere. Sorry.
ak49er says: Mar 26, 2010. 1:46 PM
I like the "wonkey" flywheel - it adds character! Plus, the fact that it works makes it even more entertaining! If there are two means to an end, and both means are just as effective, but one looks hilarious, go for the funny one!
rimar2000 says: Mar 24, 2010. 4:03 PM
Congratulations!
I'm doing a Stirling engine designed by myself (rotary displacer), but it does not work. I think it has three flaws: It's not tight enough, the cooling is very poor and air connectivity is also poor. I'm redoing it.
Yours functions very well!!
Kiteman says: Mar 24, 2010. 3:24 PM
Is that black pipe a chimney?
Does it affect the efficiency in any way?
lemonie says: Mar 24, 2010. 3:31 PM
Kiteman says: Mar 24, 2010. 3:45 PM
That lenz turbine looks interesting...
scraptopower (author) says: Mar 24, 2010. 3:30 PM
Yes, I fitted it try and stop the heat rising straight to the cold side. I don't have any evidence for it affecting the efficiency but I think that it should. It's just a piece of scrap pipe that happened to have a nice bend in it.
Kiteman says: Mar 24, 2010. 3:42 PM
That's a sound idea, any way.
I love the chuffing noise the engine makes.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
