loading
Cola can drinks are known to give you an energy boost, but what some people don't know is they can give you an electrical boost too. In this article we're going to show you how to make a cola can battery.
For more projects visit our blog.
Step 1: Materials Needed
Materials:
  • A can of cola
  • A copper coin
Tools:
  • Can opener
  • Crocodile clips
  • Wire wool
Red Devil Lye is high purity sodium hydroxide. It is probably your best readily available drain cleaner that won't have unexpected additives, a few major problems though, hydrogen and water vapor are a very explosive fuel mix off put by this reaction, sparks are a potential risk, although unlikely in a well ventilated area, other risks are chemical spills, lye will burn you, it's used for dissolving flesh and fats in a saponification process for soap making. I don't like the idea of my fingers turning into soap, nobody wants to buy melted finger soap and the pain involved in the process isn't appealing either (think fight club) . Lastly, part of that reaction involves dissolving the aluminum involved, meaning spills are likely when the container used is being ate away at. Very cool though, I was not aware that process would accelerate the electrolytic process, makes sense though. Cool experiment but the drain thing is dangerous, have a gas mask, rubber gloves, and goggles on hand. Don't preform on a surface you can't afford to have destroyed and lots of ventilation. <br><br>Also, im a soapmaker by hobby so I am aware of what I'm saying. Fun experiment, put a tablespoon of lye in a glass bottle, roll up little balls of aluminum foil and drop in bottle, take a balloon and put about a cup of water and quickly pop the balloon over the opening. Floats better than helium with the bonus of being explosive like a zeppelin.
Nice tip in itself for H2 production. Thanks
<p>Can you explain the chemical reaction taking place in the cola battery?</p><p>'cause I would have to explain it when i exhibit this project.</p>
<p>interesting, have you tried recharging the drain cleaner version of the battery??</p><p> i am assuming that the drain cleaner has sulfuric acid in it, which is used in lead-acid batteries. </p>
<p>Should be hydrochloric acid i guess as most high toxic detergent ingredient</p>
<p>i dont believe that it can charge ;d</p>
<p>Nice, may try it Doodado</p>
<div>creative</div>
<p>holy cow that is cool </p>
<p>Good Instructable! I'll have to try this experiment :)</p><p>By the way, how long does the power generate for?</p>
Be careful with the drain cleaner, when reacting with the aluminum in the can, toxic chlorine gas and explosive hydrogen are released. It is good to know that some of us are still working on how to keep the world going in the event of disaster. Nice instructable!
where does the chlorine gas come from?
According to the National Institutes of Health's Household Products Database, the crystal form of DRANO is composed of sodium hydroxide (lye), sodium nitrate, sodium chloride (salt), and aluminum. If your drain cleaner also contains bleach, it contains even more chlorine in each bleach molecule. <br> <br>Chlorine is a part of most drain cleaners. Depending upon which you are using, there may be chlorine and/or hydrogen.
<p>I'm sorry, but this makes no sense. Per your comment, Drano - in the bottle - contains aluminum, NaOH, Na2NO3 and NaCl, and is meant to be poured into copper pipes. The battery here contains aluminum and copper and Drano. There is nothing present that isn't in the on-label use of Drano. Why would it suddenly evolve Chlorine here? </p>
clorine would be only be released when using salt chem formula (NaCl) thats where the chlorine would come from, but drain cleaner (sodium hydroxide) NaOH, doesnt have any chlorine, thus impossible for chlorine gas to be emmitted. only if u use hydrochloric acid, can chlorine gas be emitted.
Drain cleaner is not manufactured to medical or laboratory specifications. There are a lot of &quot;may contain...&quot; chemicals present. Let me know how it turns out.
Thanks for the advice, that's why I recommend if your going to attempt this (the drain cleaner part) you do it in a well ventilated place. Hopefully I'll do some survival/end of world type of stuff in the future. Thanks for leaving a comment.
also that drill bit you used would have got threw the side of that can it would have ripped your hand apart next time don't use a spade bit, get a wire brush attachment
Your more than fine to use a spade bit as long as your careful and take your time.
what would happen if you put mixed mentos inside of the can. would it generate more power or less.
<p>So, when I park my truck, with the lights on, in front of the grocery store with the Radio Shack next door. I come out to find a dead battery.. ,.How many cans of cola and alligator clips will I need to jump start it? ;)</p>
<p>It will really come down to the amperage capacity of the &quot;battery&quot; you are using to jump start. I'm guessing that the Amps in this setup are relatively low. While to crank over your engine requires a large amount of amperage.</p><p>At a guess, I'm going to say more then is feasible for you to assemble.</p>
<p> Yea I once put like 2 tbsp of powdered Lye in some water .. I then dissolved 8 rolls of tin foil in that jar of water.... It produces hydrogen which of course is explosive in quantity.</p><p>Be careful with lye and aluminum cans... good thinking on the plastic tray. </p>
<p>Hello,</p><p>I have the question, how long would run a led with it ?</p><p>and how much current you can get out ?</p>
<p>You can also use any kind of salt for the electrolyte, and maybe even things like bakingsoda, but that i don't know for certain.</p>
<p>How long can you run a LED light off of these cola can batteries? Will it run for months or for a couple of days or hours? And maybe it would be an idea to find out a good kind of cap for this so that the liquid can't spill out but that any cases could perhaps escape or integrate into the cap.</p>
<p>Cool! =D</p>
<p>Great instructable, my kid swould love to try this.<br>Well documented, nice scienceproject for schoolkids.<br>Even my kids (youngest 7+) would be able to execute your instructable, good work.</p>
<p>This was my version of can batteries that I did years back. </p>
<p>Looks sweet, i like the use of skewers and copper tubing in your array</p>
Hysenburg much?
so what produces the electricity? is it the acid or the chemicals?
Well in the first part with the cola it's citric acid and the more powerful reaction at the end is from sodium hydroxide.
isn't the final picture breaking bad sytle?
Yeah, well spotted. :)
Srry but do u need to use wool
No, you could use something else to take the plastic coat off - like sandpaper.
I like it.I was wondering with all the comments about eating through the can.Cans have some sort of lining(plastic,epoxy,whatever)to protect the contents from reacting with the metal,right?
Yes the inside of the can does have a plastic coating that you have to remove (as shown in the video and step 3 of this article).
I guess what I meant was would it be feasible to put a piece of aluminum in the can so it doesn't eat through the can and make a possibly dangerous mess.Does anyone have any idea how long it takes the Draino to eat through,to prepare for the mess?Maybe use a energy drink can,they are usually thicker.
You could swop the can for a plastic or glass container, just remember to keep the lid off and do it in a well ventilated area. As for how long it will take to eat through the can - I don't know as I didn't check. But I did noticed it was making a mess of the coin.
Hmm I wonder how well this would work with a potash solution
well done.
Thanks.
I love stuff life this! You never know when it might come in handy! Thanks!
Thanks.
Today's penny's are not full copper they are only coated,, pre 1973( don't quote the year but I know it's 73 or 72) penny's are.
If I am correct there is only one penny in there yes? If so what if you had a copper pipe in there?
Yes there is only a penny in there, the idea was to show how to make a battery from the things you may find in your home. If you use better materials you may get better results.
About This Instructable
118,591views
782favorites
Bio: YouTube channel http://www.youtube.com/user/gorepairs
More by Go Repairs:Create A Cloud In A Bottle Easy way to separate egg yolk from egg white. Man Soap Hack
Add instructable to:
