3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Collapsible Bed Frame
I moved off campus this year, and had to furnish my new apartment. Mostly, I just needed a proper bed frame.
Seeing as I will be moving quite regularly for the next few years (getting started in my career and upgrading in my living spaces), I wanted to make a bed frame that would quickly and easily collapse down into a small bundle, while still being very sturdy. Additionally, It needed to not require a box spring, as those take up valuable space when moving (not to mention tough to get around tight corners).
A buddy of mine (Luke) had made a bed frame of very similar design (I kind of stole it to be honest), but his was on the floor. That doesn't appeal to me, so I added legs to make it a normal bed height.
I looked on the internet to see if there were any other plans out there for a bed frame of this type, but I could not find any that were easy to break down, and easily transportable, so this is the product of my brain.
I am sorry, but I will not be supplying all measurements, as this project was done about 8 months ago, and I lost my notes on it. Really, though, you just have to use your brain to figure out the dimensions to fit your mattress.
I have basic knowledge of woodwork, as well as very basic tools, so this instructible can be done by just about anyone.
Use your safety equipment (goggles, earplugs, gloves, and closed toed shoes).
Get your dad's permission to use his tools, and make sure to put them away when done (yes, that is a safety concern).
Step 1Materials
Materials
You will need:
A  2* 1 x 8 x 84 board (I used pine I think, but you can use nicer if you like).
B   2* 1 x 8 x 60 board (match the other ones)
C   2* 1 x 2 x 84 strip of wood (forgot what the name is)
D   16* .75 x 2.5 x 48 Premium Furring Strip (these are the slats- use more than I did)
E   1* 4 x 4 x 72  fencepost
F   12 long wood screws (whatever you have around)
G     8* 6" bolts
H   a bunch of finishing nails
I    About 12' of 550 cord or other type of strong string
Tools
A saw that can go through a fencepost (mine only went about 3/4 of the way through, and wound up with crappy cuts)
Bandsaw if you are fortunate enough to have one.
A Drill with some long bits (same problem as above)
a flat screw driver
hammer
some sawhorses
wrench to fit the bolts- or vice grip- or strong fingers
tape measure
something to mark lines- I use classroom chalk
14 comments
Mar 18, 2010. 11:39 AMfonetik says:
 Have you considered just ordering some Ikea slats for the base?  Keep the outside frame concept, and just throw some of those slats in, hard to tell from the picture on Ikea.com but they are connected by polyester strips so when not in use, you roll them up.
www.ikea.com/us/en/catalog/products/25844409
Mar 13, 2010. 7:33 PMhhorak says:
Use Velcro on the bottom of the slat and on the support that it rests on.  Slats won't move.  Helps somewhat on the bowing of the frame.
Mar 10, 2010. 12:16 PMFretka says:
 just a suggestion about the slat problem...
what if you took a simple screw and spaced them where you wanted them to be, drove a screw thru the slat into the frame to not only hold the slat in the place you want it to be, but to prevent the sides from bowing out, as the slats would hold them in....if you have a power drill anyhow, it might take an extra 10 minutes, but it would solve 2 issues and make it more stable.
I love this 'Ible btw... I do a lot of Ren Faires and sleeping in giant canvas tents, and due to my back problems I take a twin sized mattress with me and had a portable frame, this one is much more user friendly than mine,... I used 2x4's as the outer frame, welded iron corners, and 2x4's as slats...but it breaks down much like this one. This may be a great option for me. Thanks for sharing !!
Mar 14, 2010. 12:57 PMhhorak says:
one way to solve the bowing issue. You can consider using old style hook and eye latches (like on older homes screen doors) on a couple of the slats. Probably wouldn't need more than 2 - 4 slats with the latches.  Use one latch set per slat, eye on the slat, hook on the frame, tight enough to hold the frame sides to the slat end.  Too tight and it is harder to disassemble, but would bow less.
Mar 13, 2010. 9:22 PMUna says:
HI. This is very neat. Might I give my two cents on your bowing issue? I noticed that there is an end that is cut and has nothing holding it in like the other three corners. That could be part of your bowing issue. It does not seem to have anything to stop it from bowing out. The other thing is you could use 2x2's for the slats to sit upon, and 2x4's for the slats. Since you do not have a box spring you will need that extra support. The function of the box spring is to allow the mattress to give without bending. This is why those futon mattresses are so flipping hard, and platform beds have solid bottoms.
Also I am thinking a simple materials change would not hinder your goal of breakdown, and portability.
Thanks for this neat instructable. Now you so have my gears spinning.
Cheers.
Mar 10, 2010. 8:20 PMFretka says:
 ohh that is a great idea !!...the bolts would not really have to have nuts on the bottoms, as they will hold themselves in with their weight, and not slide around, and it is only a matter of a bit more construction time and a bit more drilling,but in the long run, no more readjusting the slats, or droopy mattresses.... I like that too...as long as you have a zip bag to put everything into  ( I personally use the zippered bags that sheets come in, it has a lil hanger on the top of them so I can just hang it off the brackets, and it contains my tools to put it together and breaking down of  my bed when I am at faires) then when you are ready to move, it all goes into the zippered pouch, and is packed with the pieces, and is all together for ease of putting it together again and let the boxes sit for unpacking at a later date...lol
Mar 14, 2010. 1:12 AMYerboogieman says:
I used to use a really big box spring for my bed frame, worked well and was confortable.
Mar 9, 2010. 11:30 AMkillerjackalope says:
Sweet project, is the bed itself sturdy when put together, been planning a new bedframe for a bit and swaying about what to do...
Mar 9, 2010. 8:29 PMBrowncoat says:
Great idea!
Mar 9, 2010. 11:52 AMlemonie says:
I spent a lot of time with a mattress on the floor (it was great) but this is a super build.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:andrewklove
