Step 3Inner supports
Use C & H for this
fit your frame together, then measure the strips across this. You want them to fit just inside the frame on the long sides so that the legs get some support (you'll see).
cut both to length.
use finishing nails to attach them about 2" from the top of the long sides. This gives you room for the slats, plus a bit to keep the bed in place.
I made sure to put the long sides as the top board (will sit on the short ends), as the legs will be affixed to the ends. This way, the stress isn't sitting on 2 bolts (which will make them a pain to remove, I presume).
Attached are a diagram and a photo that shows how they fit together.
Add Comment
