Introduction: Collapsible Step Poser for Photography
My wife wanted a step poser for use with her photography business. I saw similar ones to this that sold for $300 plus shipping. I had a lot of poplar and not so much time, but if anything, I'm cheap. I had to rush to get this done for some dance pictures she was doing.
You will need:
  • 3/4 inch thick lumber.
  • Pocket hole jig and 1 1/4 inch pocket hole screws.
  • Drill guide
  • 4 bolts (1.4 inch, 3 to 3 1/2 inches long)
  • 12 washers
  • 4 wing nuts
  • Sandpaper
  • Finish materials
You can find plans in Sketch Up or PDF formats.
Step 1: Cut Pieces to Size
Picture of Cut Pieces to Size
  • Rip the legs and sides to 2 1/2 inches
  • Rip the seat boards to 3 1/2 inches.
  • Cut the legs to length (4 each):
    • 24 inches for the tall step
    • 16 inches for the middle step
    • 8 inches for the small step
  • Cut the sides to length (12) of 13 inches.
  • Cut the pieces that connect the sides to length (2 each)
    • 18 1/2 inches for the tall step
    • 16 3/4 inches for the middle step
    • 15 inches for the small step
  • Cut the seat boards the sides to length (5 each)
    • 20 inches for the tall step
    • 18 1/4 inches for the middle step
    • 16 1/2 inches for the small step
Step 2: Assemble the Sides
Picture of Assemble the Sides
  • Drill 2 pocket holes in each end of the side pieces
  • The bottom side piece 3/4 inch from the bottom of the legs.
    • The top side piece flush with the top of the legs
    • Clamp and connect the legs to each side piece
Step 3: Drill Bolt Holes
Picture of Drill Bolt Holes
  • Clamp the small step sided to the middle step sides, lining up where the bolt will go through
  • Use a drilling guide and drill the holes at once through all four pieces. You may not be able to drill all the way through at once. If not, remove one of the sides and drill the remaining distance.
  • Drill recesses for the bolt heads and nuts in the appropriate way.
  • Repeat for middle and tall steps.
Step 4: Connect the Sides
Picture of Connect the Sides
  • Drill 2 pocket holes in each end of the pieces that connect the sides.
  • Connect them to the sides flush with the top of each side.
Step 5: Attach Seat Boards
Picture of Attach Seat Boards
  • Drill 5 pocket holes on the top of each side.
  • Attach the seat boards with pocket hole screws, spacing evenly.
Step 6: Finish
Picture of Finish
  • Sand to 220 grit
  • Finish with desired stain and/or clear coat.
Step 7: Attach Bolts and Complete
Picture of Attach Bolts and Complete
  • Paint the bolts to match the finish.
  • Use a 1/4 inch hex bolt with a washer on the head, another washer in between then two legs, and then another washer on the wingnut.
  • Use wingnuts so they could be dissembled quickly and used individually. The best part of this step poser is that it folds up for compact storage.
Lorddrake (author)2016-05-23
This is really cool. I have to get one of those pocket hole jigs.
mlawing (author)2016-04-15
Nice build, Ken!
CanKenMakeIt (author)mlawing2016-04-15
Thanks
About This Instructable
1,700views
53favorites
License:
Bio: I attempt to build things. Sometimes I even succeed.
More by CanKenMakeIt:Shop Project - Make a Magnetic Tray for Drill Bit StorageWooden Football Placekicker ToyMake a Pocket Hole Printer Stand
Add instructable to:
