3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Collect rain water with a wine barrel
I think I read all instructables on this site about collecting rain water.
Finally I've decided to build my own one with a wine barrel because I didn't want to destroy the look of my future-to-be terrace. I always found rain water collectors super ugly. It's usually an old plastic tank or barrel; handy but not very nice to the eye (and I didn't have the motivation to build something like this to hide it.
Anyway, here's how I did it.
Material
- a wine barrel (found on eBay for 50 EUR) - make sure to get one with a lid and a cork (usually it's a special cork located in the belly part of the barrel)
- a rain water collector to hook up to the gutter (found on eBay for 19 EUR - but otherwise available in nearly all DIY shop) - I choose that model because the collected water would come out via a little tube and not an "open-air" half-pipe
- driller
- flat wood drill heads
- some screws
- an old piece of board about the length of the barrel's lid
- a handle
Step 1Prepare the barrel's lid
Prepare the barrel\
Usually wine barrel's lids are a bit wobbly.
They are made of some planks inserted in each other, and are supposed to be inserted in a groove at the top, inside the barrel. Because of that I had to make the lid stronger so it would resist to frequent usage.
I found an old piece of wood board in my garage and screwed it tight at the back of the lid. I made sure to use rustproof (inox) screws. In order to be able to close the barrel and properly put the lid back on, (and because the lid is round) I had to saw the 4 corners of the board as you can see on the picture.
Last year we bought a new kitchen and we received two extra handles (don't ask me why), so I've decided to use one of them for my barrel.
The screws that came with the handle weren't long enough to go through the thickness of the lid + the board attached at the back. So I used a flat drill head to make a wider hole and reduce the thickness so I could properly attach the handle.
Make sure to place the handle in the middle of the lid, it's not only more beautiful but also easier to manipulate when you open/close the barrel.
19 comments
Jun 12, 2011. 7:04 AMdidgitalpunk says:
nice rain barrel! are yo french?
Oct 12, 2010. 4:04 PMsunshiine says:
Great idea.
May 16, 2010. 9:58 PMbgmd says:
 Great.  I've got an oak barrel and will do what you've suggested.  But how do you get the top off without destroying it?
Apr 10, 2010. 1:53 PMRocksterr says:
Nice handle!  I appreciate the aesthetics of  using a natural wood wine barrel as opposed to those ugly, plastic barrels.  Very classy set-up.
Aug 2, 2009. 7:16 PMalbylovesscience says:
what about cleaning the water of impurities would blech work 1tbs per gallon so how big is the drum
Aug 3, 2009. 2:51 AMalbylovesscience says:
ohhh thats a very good idea you should make a second ible for actual drinkable filtrating barrel probably a layer of sand smashed coal sand smashed coal then sand again and a lump of clay in the second layer for some better tasting water I learned that from the colony on discovery channel
Aug 29, 2009. 11:32 PMGrady says:
Frozened Juice Concentrate Distributors will usually sell there big plastic ones, along with the hardware, to put a spigot toward the bottom & one toward the top that all you have to do is screw on a water hose.
Aug 3, 2009. 2:39 PMPS118 says:
Classy! Great idea!
Aug 3, 2009. 6:27 AMBeWaterWise Rep says:
This is an excellent idea for those who do not want to invest in a rain water barrel. Given the water shortage situations in several states in the US, water conservation is important. Some more tips on how to conserve water can be found at http://tr.im/vh3u
Aug 1, 2009. 2:48 PMNinzerbean says:
Love it love it love it - I have been putting off getting a rain barrel because they are so ugly, now I can get started on this with no restrictions about putting it out front or in the back out of sight. Way to go!
Jul 31, 2009. 2:52 PMWeissensteinburg says:
It's a bit pricier, but the wine barrel looks great! Did you not add a spigot?
Jul 31, 2009. 4:03 PMWeissensteinburg says:
I know exactly how you feel...my barrel can fill up in 10-20 minutes with some moderate rain, and I'll fill up any spare buckets lying around, just so I can use even more of that water later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:chouf
