Collecting Hydrogen and Oxygen
In this instructable I'll give you a simple way to collect Hydrogen gas and if you want also, to collect Oxygen. Depending on the voltage and current that you use for the project this could be hazardous. I used a 14.4 volt power drill battery pack for the process but don't recommend it, I only used it to achieve a noticeable effect in a short time period (about 20 minutes).
Step 1Materials
Materials
The required materials are:
-Sufficient length of wire
-DC power source
-Deep water basin or bowl (preferably plastic, there is a chance you could ruin a metal one)
-Water, logically
-Weak acid (ex.vinegar as acetic acid)
-At least two plastic bottles with caps (I like the Gatorade ones because they are thicker and for some reason the Hydrogen at least will compress itself after a few days)
-A sacrificial pencil (or if you have lead [graphite] from an architect's pencil use that instead)
-Small pencil lead case or even just the cap (the refill material case for mechanical pencils)
-Tape
-Putty
-Marker to label the gases
-Long piece of tubing if you cannot find a bowl deep enough
-One sided blade or knife if you use a pencil
-You may also want other materials to plate or turn into Oxide salts
291 comments
1-40 of 291next »
Aug 18, 2011. 12:13 PMALogan97 says:
This is awesome, because I need both gases for a project I'm going to do in the near future, but am on a cheap budget with barely any lab equipment. I'll post the project as an instructable and link to this as a source of oxygen and hydrogen.
May 18, 2011. 4:18 AMubuntuPenguin says:
could you use a standard small 9V battery?
May 16, 2011. 6:40 AMwillfrey55 says:
Zinc screws? Is it possible to use some other type of screw?
Apr 13, 2011. 8:49 AMSuperKuper says:
If you use NaCl as your electrolyte won't the green bottle be full of Chlorine gas and not Oxygen? Not sure what would happen if you used vinegar. I only want to make hydrogen gas, and a lot of it. I don't care if there's is oxygen or not, I'm just going to vent it. I don't want to make chlorine, and I would prefer not to have oxide salts (not a big deal I just don't want to clean them out all the time, I just want to be able to fill it up with water and electrolytes and go).
so with all that in mind, what combination of electrolytes and anode would be best?
Jun 26, 2010. 1:08 PMtwitsl says:
Cool now I can make a hydrogen balloon.
Jun 23, 2010. 4:59 AMAttamet says:
A really easy way to get the graphite is just to take a wood pencil and burn the wood off.
Jun 17, 2010. 8:02 AMm5industriesinc says:
what brand drill battery did you use (just curious)?
Jun 7, 2010. 8:51 PMmr. clean says:
so if u fill a balloon with pure hydrogen then it will float pretty good right?
May 27, 2010. 8:57 AMnutsandbolts_64 says:
 from all the warning comments and such, I feel like I could design a hyrdogen bomb (not nuclear!). But for safety and law's sake I shall not! *designs H bomb in brain* Okay, I shall not reveal my plans! *e-mails friend (not really)*
I like the extra possibilities part. I'll say 1 for common sense, 1 for unique setup, 1 for success, and 1 for the extras. +4!
Jan 10, 2010. 8:26 PMg0tmk says:
I see many comments on here saying that I should use a car battery/charger for more amps, but it seems mine won't draw more than 20mA, why is that?  I am using an HP power supply.
Apr 9, 2010. 5:21 PMzoltzerino says:
 is your name a radio callsign?
Feb 19, 2010. 11:02 PMSmartzkid says:
They are talking about a car battery charger, not a charger which plugs into a car!
Feb 20, 2010. 12:36 AMg0tmk says:
 Hm?  No, sorry, thats not what I meant.  I do not have a car battery charger, so instead I used a HP power supply that plugs into the wall.  Try as I might though, the water never draws more than 20mA or so.  The supply goes up to 500mA, so I know that is not the bottleneck.  I've tried larger electrodes as well (the carbon rods inside dry AA batteries) but that didn't seem to make a difference.
Dec 18, 2007. 11:19 PMtricyclo-ap says:
Would there be a problem if I used glass bottles, instead?
Feb 9, 2010. 1:59 AMmarmique123 says:
that would be fine though... if you wont light fire cuz it wil explode read this here:
Lighting hydrogen in a glass container is a huge mistake, even if you get away with it. Open top or not, if the mix is within the right range of conditions it won’t combust, it’ll deflagrate or possibly even detonate with a decent level of brisance. In English, instead of pop you get “BANG!” and the shock wave shatters the container
Jan 12, 2008. 8:35 PMWyle_E says:
Glass works; it's the traditional material for most chemical apparatus.
Jan 2, 2010. 2:04 PMfireblast_1212 says:
Just get a glass jar with no air and put it in the water. Then just put a 9v battery in it. Quick and easy hydrogen. No oxygen though. Not that I can see.
Jan 2, 2010. 2:05 PMfireblast_1212 says:
Corrected. There is a small amount of oxygen at the positive part.
Dec 6, 2009. 8:52 AMdarkanima93 says:
you can also get Cu(OH)2 by using a copper electrode. When you have enough Copper Hydroxide heat it up until it turns a black color.
the reaction looks like this:
Cu(OH)2 ---> CuO + H2O
you can use the CuO in thermite inplace of the Al2O3 it might explode
Nov 12, 2009. 4:24 PMyour dog says:
How do you hold hydrogen? does the water bottle contain it well?
Apr 2, 2009. 12:57 PMnickk says:
Hello, I tried what you described step by step, what happened is that the ( - ) negative side bubbled yes but the ( + ) positive side didn't give out a single tiny buble !! , after i collected much enough of the gas, i burned it to make sure it is not hydrogen and it wasn't indeed. becasue as u said the hydrogen bubles from the positive side. So what you think is wrong here? and why isn't the positive wire giving gas ?
Nov 9, 2009. 7:44 AMtesla coil says:
How many volts did you input sometimes people dont have enough electricity
Sep 24, 2009. 10:40 AMBOOM5601 says:
I put a bridge rectifier on a power cord. It was pumping like there was no tomorrow. But then the electrodes touched and bye-bye insulation and diodes.
Sep 9, 2009. 4:28 PMbuckminsterfullerene says:
you can add a bit of vinegar to the water to help make it more conductive and therefore get better results. the only reason this works is because of the impurities in the water. if this water were pureley H2O molecules, then this would not work unless you had enough voltage to create a spark jump, but that would be around 10,000 volts
Mar 17, 2009. 7:07 PMReCreate says:
So this oxygen,Is it breatheable? What is generated more,Hydrogen or oxygen? Also if the voltage is raised,Will the gas come out faster? Also as it makes hydrogen and oxygen does it end up with less water?
Jul 27, 2009. 1:14 PMbloke2022 says:
two times as much hydrogen than oxygen
the hydrogen and oxygen is not made, it is the water! so yes the water level will go down.
Jul 27, 2009. 1:43 PMReCreate says:
Oh Ok thanks :D
Jun 2, 2009. 11:48 AMbylerfamily says:
No,the higher the amps the more hydrogen and oxygen.And no,this oxygen is not breathable.
Jun 2, 2009. 1:03 PMReCreate says:
Or so the current is what matters not voltage? And, What would happen if i breathe this oxygen?
Jun 2, 2009. 1:18 PMbylerfamily says:
The voltage matters,you want low voltage at high amps.Something like a 50 amp car battery charger would work very well.You would feel kind of blah,you might be staggering around.If you try it and nothing happens then it should be okay to breath.
Jan 2, 2011. 7:12 AMfreakyqwerty says:
Pure oxyegen is bad for you in the same way hyperventerlating is for you.
Sep 1, 2009. 12:04 PMIvraine says:
Actually, The oxygen is totally safe, it just doesn't contain nitrogen, or pollution, which makes it lighter than air. It is common in diving because it decreases the chance of "the bends" because it contains no nitrogen. It also causes better combustion because it contains no nitrogen.
Oct 27, 2009. 2:29 PMDELETED_madscientist167 says:
(removed by author or community request)
Oct 29, 2009. 2:03 PMIvraine says:
Yes they do. It does help with the bends, but they add it to pure oxygen, rather than to common air
Oct 29, 2009. 2:22 PMDELETED_madscientist167 says:
Oct 30, 2009. 4:02 AMIvraine says:
Do you mean it does electrolysis as it gets used? If so, good luck, the process is pretty slow, and while your at it hook up a flame-thrower, hydrogen burns sort of well and you get a lot of it
Jun 2, 2009. 2:25 PMReCreate says:
50 Amps? How would that work? The outlet only contains 10 15 amps at most. Would a lead acid battery do the job good?
Jun 3, 2009. 4:21 AMbylerfamily says:
You know about microwave oven transformers?They reduce the voltage and makes a huge increase in amps.Well,the car battery charger works the same way.It has a transformer which has very thick wire wound at the secondary.That decreases the voltage and increases the amps.A lead acid battery would work just fine.
Jun 3, 2009. 9:26 AMReCreate says:
ah good.
1-40 of 291next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:ferroucious
What? There is nothing interesting to put here...go away leave me alone!
