Remove these ads by
Signing UpStep 1Materials
-Sufficient length of wire
-DC power source
-Deep water basin or bowl (preferably plastic, there is a chance you could ruin a metal one)
-Water, logically
-Weak acid (ex.vinegar as acetic acid)
-At least two plastic bottles with caps (I like the Gatorade ones because they are thicker and for some reason the Hydrogen at least will compress itself after a few days)
-A sacrificial pencil (or if you have lead [graphite] from an architect's pencil use that instead)
-Small pencil lead case or even just the cap (the refill material case for mechanical pencils)
-Tape
-Putty
-Marker to label the gases
-Long piece of tubing if you cannot find a bowl deep enough
-One sided blade or knife if you use a pencil
-You may also want other materials to plate or turn into Oxide salts
so with all that in mind, what combination of electrolytes and anode would be best?
I like the extra possibilities part. I'll say 1 for common sense, 1 for unique setup, 1 for success, and 1 for the extras. +4!
that would be fine though... if you wont light fire cuz it wil explode read this here:
Lighting hydrogen in a glass container is a huge mistake, even if you get away with it. Open top or not, if the mix is within the right range of conditions it won’t combust, it’ll deflagrate or possibly even detonate with a decent level of brisance. In English, instead of pop you get “BANG!” and the shock wave shatters the container
the reaction looks like this:
Cu(OH)2 ---> CuO + H2O
you can use the CuO in thermite inplace of the Al2O3 it might explode
the hydrogen and oxygen is not made, it is the water! so yes the water level will go down.
