Introduction: Color Changing LED Tree
Ever wanted an LED tree? Well now you can have your LED tree and eat it too (no, wait, you probably shouldn't)...
Step 1: Gather the Parts
You will need:
1x ATtiny85
10x male header pins
Solid core wire, 2 colors
A bunch of LEDs
1x Arduino Uno to program the ATtiny
1x ATtiny85
A bunch of LEDs
Step 2: Program the ATtiny
To prep the Arduino for programming the ATtiny, follow the guide on this page.
After you have done that, upload this sketch to the ATtiny.
//CODE STARTS HERE
//ATtiny85 RGB color fading tree
const int 2Pin = 2;
const int 1Pin = 1;
const int 0Pin = 0;
void setup()
pinMode(2Pin, OUTPUT);
pinMode(1Pin, OUTPUT);
pinMode(0Pin, OUTPUT);
void loop() {
2to21();
21to1();
1to10();
10to0();
0to02();
02to2();
void 2to21()
digitalWrite(redPin, HIGH);
digitalWrite(bluPin, LOW);
// fade up green
for(byte i=1; i<100; i++) {
byte on = i;
byte off = 100-on;
for( byte a=0; a<100; a++ ) {
digitalWrite(grnPin, HIGH);
delayMicroseconds(on);
digitalWrite(grnPin, LOW);
delayMicroseconds(off);
void 21to1()
// fade down red
byte on = 100-i;
byte off = i;
digitalWrite(redPin, LOW);
void 1to10()
// fade up blue
byte on = i;
byte off = 100-on;
digitalWrite(bluPin, HIGH);
void 10to0()
// fade down green
byte on = 100-i;
byte off = i;
void 0to02()
// fade up red
byte on = i;
byte off = 100-on;
void 02to2()
// fade down blue
byte on = 100-i;
byte off = i;
//CODE ENDS HERE
//CODE STARTS HERE
const int 2Pin = 2;
const int 1Pin = 1;
const int 0Pin = 0;
void setup()
void loop() {
2to21();
21to1();
1to10();
10to0();
0to02();
02to2();
void 2to21()
// fade up green
byte on = i;
byte off = 100-on;
void 21to1()
// fade down red
byte on = 100-i;
byte off = i;
void 1to10()
// fade up blue
byte on = i;
byte off = 100-on;
void 10to0()
// fade down green
byte on = 100-i;
byte off = i;
void 0to02()
// fade up red
byte on = i;
byte off = 100-on;
void 02to2()
// fade down blue
byte on = 100-i;
byte off = i;
//CODE ENDS HERE
Step 3: Construct the Tree
First, start by taking two different colors of wire and cutting them into pieces (I cut them about 6 inches long). Then strip the ends off all the wires.
Solder an LED to the end of two different colors of wire (for example, I used black wire for the cathode and green wire for the anode). Then, separate the LEDs with wires attached into 3 groups.
Solder all the anodes of one group together, and all the cathodes of all the groups together, so you have 3 different groups all with a common cathode. I soldered header pins to the end of these groups so that I could easily plug it into a breadboard.
Step 4: Wire It All Up
Connect the 3 anode groups of the tree to ATtiny digital pins 0, 1 and 2 (actual pins 5, 6 and 7 on the ATtiny). Connect the single common cathode to ground.
Connect ATtiny pin 4 (ground) to the negative wire of a 3 volt 2xAA battery pack, and pin 8 (Vcc) to +3 volts.
Don't use any resistors, because if you do, the ATtiny will not have enough power to light up all the LEDs. I tried with some 1/4w 220 ohm resistors and the LEDs don't light up at all.
Step 5: That's It!
You're done! Now go in a dark room and watch the magic!
