Introduction: Color Wiimote Straps
Using some Rit dye, you can customize your Wiimote's straps. I went with Blue and Fuchsia, and at $4 per color, that's not a bad investment.
Step 1: Go to the Store and Get Some Rit Dye.
I figured that dark colors would work best, so if you get yellow, you may be sad with the results. Take your box of dye home, and mix it with 1 cup of boiling water on your stove top. Keep the mixture on the stove, and then stir in your strap(s) (I found that 1-2 straps per bath works the best). Stir it around and make sure you move the plastic on the strap around or you'll get a light spot. When you're happy with the shade, rinse the strap under hot water until it runs clear, then under cold water for a few seconds. Let it dry and you're done!
Step 2: Put the Dry Strap on Your Wiimote.
That's it! Your colored strap can go onto your Wiimote and you're all done!
