3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Color changing glowing crystal ball
Step 2Step 1: Put the led in place
Get your LED , your 5 L bottle cap and the jack cable
You will see that a headphone jack cable has actually 2 cables glued together , you may want to cut one of the cables as you won't need it.
Remove the protective plastic from one of the two cables and then get a ligher and burn the protective layer from the orange cable , so you will be able to solder on it.
After preparing the cable , solder the two wires to the LED pins , and then use hot glue to put the LED in the center of the cap.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Vladmakesstuff
I make electronic stuff.Because I Can.
