Colourful Bottle
Colourful Bottle
Decorate your room with this beautiful plastic bottle that looks like a colourful crystal.
It's very easy, cheap, beautiful and fast to make it.
Step 1Materials
Materials
You will need this materials:
-1 Plastic Bottle.
-Paints that colors water.
*If you havn't this paints you can take the ink by a pen or a marker or you can use tube with colour.
21 comments
Aug 20, 2010. 6:27 PMApplejuice11 says:
Great job, espesially for a first instructable!
Jan 12, 2008. 4:57 PMHappyChud says:
instead of cooking a plastic bottle, just pour boiling water in, that should make it easier to shape it while its heated.
Feb 16, 2009. 7:57 PM1thadeaus1 says:
you dont need boiling water, i just pushed it down and then filled it with water and food coloring and it just stayed that way...
Jan 18, 2008. 8:21 PMCrustyCrayon says:
But if you start pushing down on a bottle that was just filled with boiling water, the water can push out and onto your hands.
Feb 16, 2009. 7:50 PM1thadeaus1 says:
i just made mine!
Jan 19, 2009. 2:43 PMjunits15 says:
that is a great idea I am going to make this ,only I am going to wire an LED inside the cap witch I'll paint black.
Jan 10, 2009. 6:10 PMamakerguy says:
Thats very neat looking i think i'll make one.
Oct 30, 2008. 10:28 AMJason Ray says:
That is very cool. I made one of these and it was fast, easy, and people could not even tell if it was a bottle from a distance. Nice job.
Jun 25, 2008. 10:26 AMfiregardeneve says:
I really liked your bottle crushing idea and extended it to make this mood lighting with LEDs -
http://www.instructables.com/id/Mood-lighting-using-recycleables
thanks for a wonderful instructable. If you like what I did, please vote for it for the Let It Glow contest.
Jan 7, 2008. 12:10 AM006andahalf says:
Hey gr8 idea .... Have u thought of inverting the bottle and fit the upside down neck and cap into a pre-drilled hole in the base .... ( to look its best the bottle must be completely full of liquid .... Thanks 4 a great starter idea : - }
Dec 1, 2006. 11:37 AMjoeny1980 says:
Before reading it and just looking at the pics I thought you melted the bottles. Probably could achieve similar or cooler looking effectt (that would hold shape) by GENTLY cooking the plastic bottles. Plastic fumes are dangerous so dont do it without knowing the risk. But if I were to do it - I'd wrap it loosely in aluminum foil and bake it maybe outside in a barbeque at a real low setting. Maybe even bake while filled with water (but not in the house!). All of this has some danger to it - so dont take this as advice, and the young ones shouldnt try it. Personally I dont like the bottle cap on the top. Drill some two inch holes in a long board or box and mount a bunch upside down with some LED lighting underneath.
Dec 1, 2006. 11:39 AMjoeny1980 says:
Oh yeah - I would imagine if the your heat source is preheated it would take about one minute.
Dec 24, 2006. 6:27 PMjtobako says:
since the bottles are blow-molded (basicaly a frozen balloon) when you heat them they shrink. some will shrink in the dishwasher (some more noticably than others) and some need more heat (like trying to dry paper mache pulp in the oven). it goes very quickly over a bonfire (leave the cap off).
Dec 21, 2006. 1:01 PMwingman246 says:
u could also make the bottle have several colors by adding color to a cup of water and pouring it into the crushed bottle, then adding another color to the bottle, only some of it will mix, according to my experience
Dec 7, 2006. 3:03 PMDieffsta says:
sweet, im gonna try this out
Oct 24, 2006. 11:24 PMSpedy says:
This is pretty neat. I'm gonna try it the next time I have some time to burn. good instructable.
Oct 22, 2006. 3:54 PMfoamyguy says:
I really love the way LED's look when you put them under a bottle of liquid. if stuck a throwie minus the magnet underneath it it'd look pretty cool, just keep a piece of plastic or paper to slide in to turn it off. And also if you don't have the ink / paint you could consider brightly colored drinks(gatoraid or poweraid work well) and in the unfortunate event that it should spill it won't be as likely to stain. And if you for some reason want to switch colors but reuse the bottle these won't stain the inside of the bottle.
Oct 21, 2006. 7:21 PMTheCheese9921 says:
nice maby someone should incorporate some LED's (hint hint) cough cough very kool
Oct 22, 2006. 9:42 AMMurf says:
I was actually looking for a neat container for a liquid + LED project. This should do perfectly. Now I just have to have some free time to do the project. I'll post it whenever I have the time ot actually do the project :P
Oct 21, 2006. 8:54 PMtyeo098 says:
I dont know, my last couple of projects with elec+water didnt exactly turn out well... otherwrise, great project!
Oct 21, 2006. 6:51 PMaustin says:
thats pretty cool id like to do this with like epoxy resin or something to make it harden. and give it a feeling of mass
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mercurius
BE THE BEST!!!
