The colouring trash picker is a tool with which you can clean the streets and at the same time colour them! The graffiti can attached to the trash picker, will spray paint by pinching the handle of the trash picker which you also use for grabbing the trash.
In the list below you find everything you need for making this tool. It is possible your trash picker does not work exactly the same as used for this construction. In that case maybe some adjustments are necessary to make it work.
Parts:
- Trash picker
- Graffiti can
- Hose clamp app. ?0,6 inch (15 mm)
- Hose clamp app. ?2,75 inch (70 mm)
- Bolt, spacer and washer M4
- Metal strip 0,8 inch (20 mm) x 9,8 inch (250 mm)
- Metal tube ?0,65 inch (16,5 mm) inside
- Metal stiff wire ?0,079 inch (2 mm), length depends on length trash picker
Tools:
- Screwdriver or wrench
- Ruler and pencil
- Drill machine
- Metal saw
- Welding machine
- Wire cutter
Remove these ads by
Signing UpStep 1Get yourself a trash picker and graffiti can
Just like this trash picker, most of them work with a cable walking through the pole.
By grabbing the handle, an axle moves to the back on witch the cable is connected. On the other end (the bottom end) the cable is attached to the grabber, which closes due the pulling movement of the cable.
You also need one graffiti can already, for being able to adjust the construction to the right can size and making sure youre construction works!
Trash can be really interesting if you look at it's context. It tells stories about what is happening around. The amound of trash and the kind of trash. At unused spots, like a broken down building, the trash quickly collects. This project is about upgrading this waste land, by removing the trash regularly, but leaving its silhouette behind. The longer the waste land is exhisting, the more colourfull it becomes.
