Step 3Make the metal strip that will push the graffiti can
iImage Information
Saw a metal strip of approximately 0,8 inch (20 mm) wide and 9,8 inch (250 mm) long. Bow the last end of the strip on 35?. On this end, you weld a metal tube that will fall over the head of the graffiti can. The inside diameter of the tube must be the same size of the head of the graffiti can, this is ?0,65 inch (16,5 mm). Saw this metal tube so it will be 0,5 inch (13 mm) high. Drill a small hole in this tube, this is were the paint will be sprayed through. Drill a hole of approximately 0,275 inch (7 mm) on the other end of the strip. We will use this hole to attach a metal stiff wire to the strip.
