loading
Step 13: Losing Weight
One way to lose weight is replacing the armor with armor that weighs less. This will work if you need to lose a lot of weight. But if you need to lose just a little weight, you can drill holes in the base plate. Another alternative is to get lighter parts.
<p>Does anyone run micro-controlled insect weights. Would an arduino or pi stand up to the abuse. Or is there another reason why they are all directly RC controlled? </p>
<p>It's not exactly Arduino, but there's an Atmel based dual channel programmable ESC that I plan to use on my Beetle weight bot. It'll control 2 sets of brushed motors for tank style steering. </p><p>It's not just an ESC, they provide the source code for the ESC, and allow you to program it and use the remaining I/O pins for sensors, etc. What's exciting to me is that this costs about $20, and replaces $60 worth of ESC, while adding autonomous capabilities. </p><p><a href="http://www.robotmarketplace.com/products/0-PL1220.html" rel="nofollow">http://www.robotmarketplace.com/products/0-PL1220....</a></p>
Oh cool thanks I look into it.
<p>Not that I've seen. RC is common because it is easy to set up and a human controlling the robot is typically going to be better than an autonomous system. However, arduino and raspberry pi should be able to handle the same abuse.</p>
Ah, okay. I am thinking if using a Bluetooth controler on the arduino. Just seams like nobody does this and I was wondering why. But I guess RC is easier.
<p>I was wondering, there are multiple gear ratios of the motors, does which one I get matter? Will the gear ratio affect the size of the wheel as well? Sorry, I'm quite new to this.</p>
<p>Yes. The higher the gear ratio, the slower the motor will spin, but it will improve acceleration and reduce stress on the motor. Don't go gear to high, though. Too high and the speed of the robot will be a crawl.</p><p>Wheel size effects the gearbox, not the other way around. A larger wheel requires more toque to spin(ie; will cause the motor to eat more amps), but will also improve top speed. Beware, if the wheel is too big, the motor WILL fry itself just trying to spin it. Smaller wheels require a lot less effort to turn, but will result in lower overall speed.</p><p>What kind of speed and acceleration you'll need will depend on what the bot is doing, the weight of the bot, and the size of the arena. My rule of thumb is to be at max speed by the time you've reached the middle of the arena, any speed you'll have will be more than enough to work with. My current antweight(1lb) runs a pair of 11:1 Fingertech spark motors at 7.4 volts(Unloaded speed of 1049rpm) with 1.5&quot; wheels, and the speed and acceleration are spot on for my needs. You may need to bump up the gear ratio or change the wheel size to get a speed you will like.</p>
hi,i am an student.i am taking part in an manual robot fighting competition but i don't have any idea about what type of robot to build and the rule of competition is_1. U cannot damage other's robot_2.you cannot exceed the weight of robot more than 3 kg and size more than 30 cm l*b*h_3.u cannot use any weapon except a wedge_4.u cannot damage the game arena .what should i do.plz help me.thank u
<p>How do you connect the sprocket to your motor?</p>
<p>Nice blog thanks for sharing useful information. For more robotics tutorials and learning visit http://www.robotictutorials.com/</p>
<p>Thank you! This was major help! I was just having problems coming up with a good design, and this helped a lot! </p>
<p>Hello, me and my friends are entering in the antweight category for RoboGames 2016. Would this micrometal gearmotor be good for the drivetrain? <a href="http://www.amazon.com/gp/product/B00O8G2REY/ref=ox_sc_act_title_8?ie=UTF8&psc=1&smid=AX0L6PQFFBO02" rel="nofollow">http://www.amazon.com/gp/product/B00O8G2REY/ref=ox...</a>]</p><p>Also, would a 460mah 3s turnigy nanotech be able to run two of those motors and one of these: <a href="http://www.amazon.com/gp/product/B00W6XPFX6/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=AFP72QUFLN3JX" rel="nofollow">http://www.amazon.com/gp/product/B00W6XPFX6/ref=ox...</a> for my weapon well?</p><p>Thanks in advance!</p>
<p>Dude, those motors have like no speed. If want decent motors for a weapon baring ant(which you failed to state what kind of weapon it is too), you might want to try these motors:</p>
<p>I switched it to 2s, but similir mah</p>
<p>what did you make your drum out of? what would be a good weight for a drum in the beetleweight class?</p>
<p>If you don't have a lot of tools you could take some steel or iron pipe and drill holes into it. Then after drilling the holes feed a bolt through them and thread on a nut. Last cut off any excess threads off the bolt that stick out past the nut. You don't need a welder so that is helpful. This design will let the head of the bolt and the nut catch onto other robots. </p>
<p>which SPEED CONTROLLER....should be used for beetle&amp;ant size combat robot</p>
<p>Fingertech tinyESC man.</p>
<p>what would you say are the average dimensions of a beetle weight robot?</p>
<p>Hi Jared</p><p>Can you suggest an ESC for this weapon motor?</p><p><a href="http://www.hobbyking.com/hobbyking/store/__39038__Turnigy_Multistar_2814_700Kv_14Pole_Multi_Rotor_Outrunner.html" rel="nofollow">http://www.hobbyking.com/hobbyking/store/__39038__...</a></p><p>Since the motor will be driving a weapon with far too much angular momentum, I need it to be able to coast to a stop. The 30A ESC that I already bought occasionally makes weird sounds and stops responding if I let go of the stick and let it spin down. It works fine if I program it to enable braking, but that just won't be feasible when I attach the weapon to it. Here's the ESC that I bought:</p><p><a href="http://www.hobbyking.com/hobbyking/store/__30931__hobbyking_red_brick_30a_esc_us_warehouse_.html" rel="nofollow">http://www.hobbyking.com/hobbyking/store/__30931__...</a></p>
<p>The ESC you have should work when braking is disabled. It's hard to tell exactly what the problem is without being able to see it. If you could post a video to youtube and then send me the link I'd be able to help you more.</p>
<p>I can't post a video until this weekend since I don't have it with me at the moment. Maybe it's just a defective ESC. I bought another one at the same time, which burnt up. So perhaps they are just especially poor quality.</p><p>Here's an animation of what the final product is going to look like. (SolidWorks is awesome)</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/jogzrcZnpCQ" width="500"></iframe></p>
hi I am just a beginner. i am wondering what type of battle bot i should start out with. thank you
I recommend building a wedge as your first robot because they are easier to build. I now well antweight kits that are great for beginners if you are interested in those. They are available at http://www.titantechindustries.com/
thank you im more interested in building my battlebot from scrach instead of a kit but i will check kits out to. thanks again
I can understand that, building from scratch is very rewarding. If you build your first robot from scratch I recommend mainly focus on just getting it to function. It may not do great at a competition, but just taking a functional robot to a competition is a great place to start. You'll learn a lot in the building process and at the event that you can use on a second version. My first robot (the one in the main picture) was actually kind of terrible. I did a lot of things wrong, but just by taking it to a competition I learned a ton. Even though it wasn't a good robot it somehow managed to get 3rd place, which is ridiculous. There were a lot of other robots at the competition that were better so I just got really lucky.
i am a beginner and want to make a combat robot i like one in the range of 2-10 pounds .Can you give me some suggestions on what type of robot to make
The best kind of robot to build as your first robot is a wedge, because you don't have to deal with the complications of a weapon. Usually 1lb robots are the easiest to build as your first robot. 3lb robots are also fairly easy because you have more weight to work with.
Hi, <br>Do you recommend another motor for fairyweight? a faster one with a shaft large enough to fit finger tech wheels (0.5in or 0.75 inches of Width) <br> <br>Thank you
Are you building a featherweight (30lb) or fairyweight (150g) robot? For a fairyweight I recommend the new mini sparks that fingertech will be releasing soon. There will likely be several gear ratios to pick from that will determine the speed. The shafts on these motors will likely be 3mm (~1/8&quot;) as that is what the size of hubs wheels fingertech makes. <br> <br>If your original question about motor mounts was about fairyweights rather than featherweights, then absolutely you can use UHMW as a motor mount material. That would likely be my material of choice of a fairyweight motor mount because it is strong enough and very light. In my last reply I said I didn't have much experience with featherweights. However, I am much more experienced with fairyweights as I have built one and I am familiar with the components because they are sold on the websites I frequently by things from for my antweights (1lb). <br> <br>If this is your first robot I recommend building a fairyweight or an antweight because they are much less expensive and are easier to build than a featherweight.
Im building both!<br>But Im focus on the fairy now.<br>I dont have time and I need a fairyweight motor to fit FT wheels. <br>The 100:1 RMP is to slow and the 30:1 is to short on the shaft, even the lectra wheels wont fit.<br>Do you think 5mm armor wall's will be fine on combat?<br>Thank you for the help!
The 30:1 should be fine for the lectra and lite flite wheels if you use a lite flite hub that fingertech sells. The shaft doesn't have to go very far into those because the set screw part is about 1/4&quot; deep. I used some 30:1s with lite flite hubs and they worked fine in my fairyweight.<br><br>Depending on the material 5mm should be plenty. My current antweight uses 3mm UHMW in some places. I'm not expecting the 3mm to hold against most weapons though but it should be thick enough to protect the electronics even if the UHMW gets torn up during a hit.
I dindn't knew about that, I though the lite flite hub couldn't support the wheels. <br>Do you know any material besides titanium, to use on a vertical spiner weapon?
For a 150g 1/8 Ti should be fine. For higher weight classes I recommend heat treated S7. It will hold up well to almost anything.
Thanks for the answer!! <br>I have another question, about speed controlers and motors. <br>If for instance i have a Victor 884 with the Maximum Current of 40A continuous, and use it to control the CIM Motor(12V DC), with a Stall Current of 133A. In the case of conecting a LiPo battery(12v) to control the motor the Esc's will burn? No way I could use this combination? <br>Btw do you have a active robot for this year?? <br>Thank you <br>
Victor 884's should be able to control a the CIM motor you're talking about, I put the numbers from the motor into this calculator, http://www.architeuthis-dux.org/torquecalc.asp, and it shouldn't get close to stalling. Most of the time motors won't reach their stall current because the wheels will start to spin before then. I only build insect weight robots, so I don't have much experience with what motors people are using for featherweights. People from the RFL Forum or the Facebook group called Robotics Community are more knowledgeable in the higher weight classes than I am. You might want to ask around on those forums to see what parts they use. I do have an active robot. It is an antweight called Guildenstern and I plan to compete with it at the Central Illinois Bot Brawl in April (http://www.buildersdb.com/eventdetail.asp?eventid=363). It's been about a year and a half since my last competition and I've been working on the robot on and off since then. If you have any other questions please ask, I'll do my best to answer them.
Hi! <br>Do you think UHMW motor mounts should work fine on Featherweight?
UHMW probably wouldn't be the best material in a featherweight. I recommend aluminum because if you face mount the motor (screw through the mount into the front of the motor) UHMW wouldn't hold up too well if one of the wheels gets hit. Also, if you use a clamp style mount with UHMW in a featherweight the torque the drive motors in that class generate could make the motors spin inside the mounts because UHMW is kind of a slippery material.
hello im trying to make a beetle weight bot and I'm trying to figure out what battery to get. the motors im planning on using are the &quot;FingerTech spark 20:1 Gear motor&quot; and im looking at this battery it is a E-Flite 1800mAh 2S 7.4V 20C LiPo Battery, 13AWG EC3. i am also using the smallest sabertooth esc the one rated for 5amp continuous and 10amp max per channel. I would greatly appreciate any feed back you can give on the battery subject. Is it a good one? will it work? and why are there two leads comming off of the battery? <br>the links to the above mentioned items are below. thank you for any help you can give in advance. <br> <br>-ahleagle <br> <br>motor: <br>(http://www.robotmarketplace.com/products/0-FT-SPARK16-20.html) <br> <br>esc: <br>http://www.robotmarketplace.com/products/0-SABER2X5-RC.html <br> <br>battery: <br>(http://www.amazon.com/E-Flite-1800mAh-7-4V-Battery-13AWG/dp/B000YUTIVI/ref=sr_1_1?ie=UTF8&amp;qid=1356744401&amp;sr=8-1&amp;keywords=lipo+battery+7.4v+e-flite)
For the drive motors I recommend that you don't use the gold version of the sparks. They are not intended for combat. Silver spark are much more suitable for combat and are made by the same company. You should be able to find them from robot marketplace. I have never used silver sparks in a beetleweight but I know of other builders who have and they have had success with them. You will probably have to run the motors at 4S (14.8V) for them to work effectively in a beetleweight though. If you don't plan on having a weapon the silver sparks won't be powerful enough for a wedge robot. <br> <br>For the ESC I recommend fingertech tinyescs. They are the same price (or pretty close) as the sabertooth and are tremendously better. I have used the sabertooth escs before and had a lot of issues with them. If you get the tinyescs you have to buy two, one for each motor. <br> <br>The battery had two leads because it is Lithium Polymer (LiPo). One lead has the positive and negative (red and black) wires which connect into you robot, these are like the normal terminals on a battery. The other lead has the wires which connect to each individual cell of the battery. This lead is used when charging the battery, because the cells need to be kept within .1V of each other to avoid damage to the battery. LiPo battery chargers take care of keeping the cells within .1V of each other when charging. <br> <br>That battery is likely too low of voltage if you use silver sparks, and too high of a capacity. I don't know what capacity you need for sure with out knowing weapon specs, drive motor, and tire size. But, 1800mAh is a little overkill unless the weapon draws a tremendous amount. <br> <br>This will help with motors and battery choice, at least for drive anyway. <br>http://www.killerbotics.com/kbtools/TentacleTools/ <br>Silver Sparks aren't an option so you will have to input their specs from fingertech's website.
What gear ration would you recommend for a Beetleweight in the finger tech spark series silver motors?
Perhaps a good defence against saws might be multiple thin plates that could get torn off without doing major damage to the robot. It also might work against spear bots.(The top layer cracks, then the next... giving you more time)
what about carbon nano-fibers? they are very strong and durable. stronger than diamond, actually.
And they can't be produced in useful quantities yet, or for a reasonable cost.
i have an idea. how about using a mag lev to hold up the upper half? neodymium magnets work best for mag levs.
how would i make a flametrower i mean i know how like all i need is some wd40 and like a candle but i dont know how tospray the wd40 from a good distancent<br>
please i just advise that you keep the wd40 away from flames even read it on the safety label if you really want more info in fact it is a hexagon danger of flammablity and same with pioson
If you watch the UK robot wars, you see that Seargeant Bash has a massive nozzle and underneath it, there is a tiny little flame. Gas goes through the metal tube,and through the metal nozzle, so the flame 'throws' itself. You might find it a bit hard, but that's all my knowlege. Good luck!
You could just mount a servo on top of the can of WD-40 to press it down. &nbsp;It should spray far enough by itself if it has a straw on it. &nbsp;Also, you would have to use some sort of electric ignition device (way too fancy of a name), like a wire that gets hot or a gas grill sparker, because they wouldn't let you have a candle on your robot. &nbsp;Most competitions don't let you have flamethrowers at all.
why dont u hav wheels on the front of the robot i im making one too ill take photos and put them up
About This Instructable
94,614views
194favorites
License:
Bio: I like regular robotics and combat robotics. I also like just about anything that has to do with instructables.
More by JaredsProjects:No-Drill Dorm Room Curtain Cryptex Wire Organizer
Add instructable to:
