"Yeah, it's strange that they don't make a circular saw that just snaps into a table so you can use it as a table saw."
And thus the seed was planted. I remember at the time I brushed it off, but a few days later a friend and I decided to sketch the plans out for one and try to make one with three criteria:
1) Make it cheap.
2) Design it so that all you need to build it is a drill and a circular saw.
3) Design it so that you can easily remove the circular saw when needed.
The video below is a time-lapse of us building our Circular/Table Saw over the course of ~4.5 hours. We were planning as we built, so I am confident that this could easily be replicated in 2-3 hours.
Remove these ads by
Signing UpStep 1Materials
Circular Saw (More on this ahead)
Drill
Optional Tools:
File
Chop Saw
Hardware:
1/4" 20 Machine Screws
1/4" 20 Wingnuts
1/4" Lock Washers
2" Wood Screws
3" Wood Screws
Zip Ties
Lumber:
3 2x4's (Pine)
2 1/2x1's (Pine)
2' by 4' sheet of particle board
Everyone has their own method of selecting lumber, we like to look down the length of the wood and search for warping. Sometimes I like to lay the wood on the ground and see if it rocks or falls over, but this method requires the floor is even. Finally, make sure there aren't too many knots.
All in all, this project should cost less than $70. That's including the cost of the circular saw and all components (but assumes you own a drill and the necessary drill bits).
I maked years ago a cutting table like this, and it have been very helpful. I still use it on a regular basis.
Just to let you know that what you are showing up here is extremely dangerous. You really need to use a miter gauge when crosscutting on a table saw NEVER a fixed fence as we see in the photo. If the angle of you wood piece had changed for any reason while you were riding against that fixed fence the blade would have catched it and throw it across the room or worst in your face. I learned this the hardway and received a piece right above my family jewels (ouch!).
here is a video where a pro makes the same statement.
http://www.ehow.com/video_4427310_cross-cut-table-saw.html
be safe and enjoy you new toy!
A circ saw is more likely to stall than to throw a piece of any size.
I did something like this many years ago, but wanted to be able to use a miter gauge. I also wanted to be able to remove the saw to rip panels, etc.; and then return it to the saw table quickly so that it is in the same precise alignment it had when I removed it. I also wanted to make precise rip cuts. My Instructable appears in the related Instructables above, or you can view it here. It was very little effort than what you did, but should give you some additional useful features.
http://www.instructables.com/id/Convert-a-hand-held-circular-saw-into-a-table-saw/
How's the table saw holding up?
I used it a lot for several months. I ended up finding a good used Delta for 100 $, which was a good deal. If I hadn't found a cheap saw, I would have continued to use my DIY saw.
