loading
Step 8: Cut Out Recess for Miter Saw
It would probably be easier to cut these pieces ahead of time and assemble a pieced-together top surface instead of one entire continuous sheet that then needs to be cut apart in place, but this is just how it worked out for me.  You can absolutely plan ahead for this and make these cuts on the table saw and box out the recess for the miter saw before you screw down your top panel.
The dimensions of your recess are dictated by the height of the bed on your miter saw and the room that the saw needs as it swings through it's entire range of motion and miter.  My 12" sliding compound miter saw needs almost 3 full feet to move freely, so that's the size section that I cut out from the work surface.
Cuts were made with a circular saw and then cleaned up with a hand saw and jig saw to get into the hard to reach places.
Take care to measure the exact recess that your saw will need from your top work surface so that the saw bed is exactly flush with the height of your side supports.  OR, don't worry about it too much and make sure that you cut DEEPER than your saw bed and prop up the saw on some shims later.  I went this route, planing down stock to the exact height that my saw would need to be perfectly flush with my top work surface.  I think this is the way to go rather than trying to make precision cuts with a circular saw.
Once the cuts are made, box out the sides of the recess and screw in a bottom.  The bottom I used was part of an old desktop.  It's very heavy and solid, and what's more, has a nicely curved front edge which was perfect for me since it nicely mimics the arc that the saw makes when it's adjusted to make miter cuts.
I supported the bottom of the recess with a single cleat in the back that was cut with that same 8 degree bevel since it's mounted onto the angled vertical panel support.  The front of the recess bottom panel is screwed directly onto the front vertical panel of the station that it rests upon.
See photos.
<p>@joel.munzo.7547 Here is a PDF of the Miter Stand Drawing</p>
Very nicely done! A very practical storage and mitre saw solution. Do you mind if I draw up a set of plans for it, I believe it is something a lot of woodworkers with limited space could use.
My plan drawing skills are virtually zero, so, I'd absolutely love it if you would consider drawing up some plans. You can post them to the Instructable in the comments, but once they're up, I'd also love to include them in the Instructable itself in the tools and materials section and of course give you credit and many thanks for them. How can I help, and seriously, thank you!
Hey brother, would you happen to have a pdf. file that you could email me by chance? I click on all the links and none of them work. I would greatly appreciate it.
NoahW I can't rember how to attach the pictures, I add them and hit preview which did nothing. Posting just posts the comments. Help!<img src="http://img.instructables.com/files/deriv/F8X/MXAD/H2MYKD37/F8XMXADH2MYKD37.SQUARE.jpg"><img src="http://img.instructables.com/files/deriv/FFT/CTTA/H2MYM72J/FFTCTTAH2MYM72J.SQUARE.jpg"><img src="http://img.instructables.com/files/deriv/FHA/0RNJ/H2MYM72G/FHA0RNJH2MYM72G.SQUARE.jpg">
I'll reply via PM with my email address. You can send them there and then I can upload it to the Instructable directly. If you'd like to post in the comments - try clicking "add images", then select them, upload them, and just click post comment without hitting preview first. Not sure if that will work, but it's worth a shot. <br /> <br />Thanks so much for the plans - from the thumbnails you uploaded they look awesome!
Sorry Noah I couldn't figure out how to make them bigger, so we'll go the other route. Cheers
I've attached the sketchup file to the Instructable. Thanks so much for drawing up these plans!
Man, this was a blast to build and is incredibly useful. I was able to get my wood stock off the floor, have a perfect chop saw station, and even a little out-feed table space too. The casters make getting it around the shop super easy. Well done on the instructible as well. Maybe the best I've seen.
<p>Not that's a gorgeous DIY storage bench if I ever saw one. Kudos to you for taking the time and effort to make one mate!</p>
Hey, this looks great!! One thing that pops into mind is saw dust and dust collection. I wonder if you included a space for a cyclone vacuum bin with an autostart, maybe a downdraft bed under the saw, if that would keep a lot of dust out of the air. Very nice build btw!!!
<p>Damianzuch,</p><p>Thanks for pointing this out. I was about to make something similar and completely forgot about the sawdust issue that comes with these type of stations.</p><p>Thanks for the heads up.</p>
<p>Very cool. If I ever had my own shop I'd make this.</p>
<p>One note - pipe sizing is wrong. I went off the materials list and bought 1.5&quot; and 1&quot; pipe ........ I think the author meant O.D. which is not how pipe is sized. </p>
That's intense...! Thanks for the instructable!!
i LIKE IT, WELL BUILD, I'M GOING TO TRY TO BUILD ONE FOR MY GARAGE SOON. THANKS TO SHARING.
How deep is the work bench?
haha nice. Wish I would have seen this one before I made mine. Funny, how similar in concept they ended up being. Very nice,
Great project! You have successfully combined your need of storage and organization in one working space. Congratulations for a job well done!
What an awesome build! I will share this with my son, he will be building guitars in a year or so and will need something like this! Thanks so much for sharing! <br>Hope your day shiines! <br>Sunshiine
I have a radial arm saw still sitting on the floor while I think of a way to set it up. This would be perfect (if I had the space). This is a great way to make double use of the space. I did a LOT of research when constructing my small shop and I definitely would have added this into my shop. I built something similar using my workbech instead. Excellent instructable man.
genius,genius.lots of thanks from greece
As someone who is very particular about organization I just have to say this is sooooo beautiful.
I really like the functionality of this and how well you maximized the space. I have a similar set up, although I store all my long clamps underneath rather than wood, as you have done... (Hmm. I just need more shelves I think?) <br> <br>Plus, you've added lots of good details that I will eventually have to copy, especially the storage for sheet material behind. Awesome work. Thanks! ...And welcome back!
That is a superbly designed cutting bench. Thanks for posting it, so many good ideas there.
Approximate cost?
Depending on what you pay for your plywood sheets and the heavy duty casters, the entire build is between $200-$300.
Not bad. Thanks for that, just so I can estimate a ball park figure could you tell me what you pay for yours? (and what grade please).<br><br>I notice I haven't said previously, excuse me for that, but, nice job!
The heavy duty casters cost around $12 a piece on Amazon, I scrounged for the chair casters off an desk chair that someone was throwing away on the street. They are around $9 a piece though if you want to get them online. Home Depot offers sanded 3/4" plywood sheets by the checkout counter in Emeryville, CA for around $30 a sheet. It's not great stuff, but it gets the job done and at least won't give you splinters. <br /> <br />Screws are $5 a box, need big ones and short ones. The steel 1/4" rod is pretty cheap for a 20 foot length at a local steel yard. All the steel rod for this project shouldn't be more than $15. 2x4's are $2.75 at home depot, the steel pipe was scrap that I salvaged from a buddy of mine who is a metal worker and the PVC was a couple of bucks a length. I think that's everything.
Thanks for that, very helpful. I would estimate that, on local prices, the cost for me would be $500-$600. Still not bad, I must give it some thought. I might substitute MDF for the plywood or something like that. Cheers, enjoy your wonderful creation.
Where are you located...which is to say, what accounts for your increased costs?
I am located in Australia - the closest I can get to your plywood spec is structural CD 2200 x 1200 x 17mm @ $65 a sheet. <br> <br>MDF 2200 x 1200 x 16mm is $31 a sheet - BTW 2 years ago it used to be 19mm at the same price...
Wow. This is perfectly thought out and implemented. Great job. I will definitely be building this or something very much like it. <br>Kudos!!!
Nice! <br> <br>But for a stationary tool on a workshop, why would I go for a compound miter box when a radial arm saw would be far more flexible? <br> <br>I always assumed the advantage of the miterbox was that it was portable.
That's a very good point - I sometimes run up against the limitations of my sliding compound miter saw, mainly the crosscut depth on really wide boards. Maybe in the future I'll think about getting a heavy duty radial arm - I see them used on Craigslist all the time.
Phil B has a nice tutorial on R.A, saws here on this site. <br> <br>The miterbox also has the advantage of being quick and easy to set up for the things that are within it's capacity.
I found myself using my miter saw 10x more often than my radial arm saw. I finally sold the radial arm saw and have never missed it. I use the miter saw often, long boards for ripping I clamp and use a circular saw. Smaller storage requirements and I often used my radial saw table to store things on. So, I was always digging it out. This bench gives you cutting, great storage and a wood bench for assembly. <strong>Great job and idea!</strong>
I plan on building a similar station and think yours is really well done and I admit I will blatantly steal some of your features in mine. I'm adding one thing that will make the station more useful and make the tool mount shelf swap-able. By using a sliding mounting board I'll be able to use the station for sawing, routing thickness planing etc.. Unsnap the saw mount, slide it out and slide in a panel with the next tool I need. By adding a rack nearby I can also store unused tool mounts using the same sliding system and store several in a small footprint. Anyway, great looking and functional design. Well done.
i think this is wonderful but modding it for multitool is a great idea!!! <br>i cannot wait to see your plans .
I think this is a great idea that would work for lots of tools. One quick thing to thing about is how to adjust for the varying bed heights between tools. Each shelf could zero out on it's own custom mounted sliding rails seems like the easiest thing to come to mind...but of course, if you wanted to get complicated you could also have a gear driven crank system with a bed riding up and down some threaded rods. Anywho, lots of cool ways to modify and I like your idea of having modular tool slide-ins a lot. Thanks for your comment and post pics/Instructables of what you make should you go for it!
Very nice. I like the use of space. You know it's these type of projects that get us motivated to build our own!
Very cool! Hats off to you.
Oh, boy! I can see my hub checking his lumber pile, even as we speak. That's one great-looking set-up. Good work!
That is just gorgeous. <br> <br>I don't know if I'm more jealous of the bench or having a large enough workspace to put it in.
it looks a bit, Art Deco-ish!
I need a bigger garage! Nice work.
Nice job !&acirc;€&brvbar;
Very nice design
Fantastic work! I want! I want!
About This Instructable
117,198views
1,069favorites
License:
Bio: I've worked for Instructables off and on since 2006 building and documenting just about everything I enjoy doing. I am now the Creative Programs ... More »
More by noahw:How to Send Art Into Outer Space Cómo soldar 意式烤面包食谱
Add instructable to:
