I usually just stick the sleeve/desk (sans strap) in my backpack, but you could use it on its own with a strap as shown.
Remove these ads by
Signing UpStep 1What you need
I cut a piece of 1/8" thick laminate pressboard I had lying around a little smaller than the dimensions of the bag and then filed and sanded the corners and edges smooth. You could use any material that is light and stiff enough.
And then some 1" wide stick-on velcro that was lying around.
Disclaimer: I know it is a bad idea to heat up plywood, because it will give off toxic gasses, but I have no idea if this would be a problem for the amount of heat that a laptop might generate. Always compute in a well ventilated space!
comments
Add Comment
Weissensteinburg
says:
Add Comment
