Commodore 64 MOS6581 SID Based Synth / Sequencer by Technoshaman
Featured
This is an old project of mine from about 3 years ago. I was 8 when my father bought me a C=64 28 years ago, and I still remember how thrilled I was to play with it (I'm still a gamer and a hardware hacker thanks to it), and the main thing for me in most games was the epic music. So after many years, I decided to make a little synth based on the famous MOS6581. I lost my patience when it came to creating the patches (instruments made from using separate oscillators at different settings and times).
So this is a basic module you can experiment with, it allows you to play with the raw register values (but there's also the code for using it as a programmable 16 step sequencer, or a MIDI controlled synth).
The circuit consists of a MOS6581 (from old C=64s, the ones I got from e-bay had faulty oscillators, but I got a refund), a PIC18F452 (the brain), 2 shift registers (to be able to communicate with the SID serially, using the 8 data and 5 address lines), a 4x16 character LCD for display, a MAX232 for serial communication with a PC (never really used it for a purpose other than bootloading the firmware), an optocoupler for the MIDI input, a LM386 for direct audio output, linear regulator ICs, some connectors, switches, and pots.
Step 1:
Here's the schematic and a screenshot of the PCB. The circuit was designed on Proteus Isis, then transferred to Proteus Ares for the PCB design. The code and the schematic are self explantory. If you have any questions, please ask.
Harrymatic says: Dec 27, 2012. 6:01 AM
Great project! Finally I have a use for the SID chip that's been rattling around my parts box.
Technoshaman (author) says: Dec 27, 2012. 6:50 AM
Thanks a bunch! I hope this Instructable provides some help :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
