Introduction: Commutator Clapper On/Off Ligth
Picture of Commutator Clapper On/Off Ligth
This circuit consists of a microphone which can enable or disable a light attached to it, by the sound of applause,
when applause for the microphone is detected, the signal is transmitted to a preamplifier, which consists of a transistor and resistors
The output pulse of 555 activates the clock inputs of a JK-type counter, the integrated 7493.
The 7493 is configured to use one of the flip-flop internal which will keep the active signal, applause is needed for the output Q1 of the flip-flop through the high state and activate the Q1 transistor, which in turn activates the relay .
The transistor energizes relay coils allowing the bulb switch.
List of components
  • Breadboard
  • Transistors 2n 3904
  • Timer 555
  • Integrated counter 7493
  • Diode 1n 4004
  • Relay JQC-3F
  • Battery 9v
  • Capacitors & resistors
  • Wire UTP
Step 1: Preamplifier
Picture of Preamplifier
In this step we build the preamplifier will be necessary for our microphone, as the voltage is very small, must be amplified.
The preamplifier is a 2N3904 transistor, configured feedback. The positive pin of the microphone is connected to Vi, and the other to ground. The amplified audio output is on pin Vo.
Step 2: Timer 555
Picture of Timer 555
The 555 timer aims to convert the analog audio signal coming from the preamplifier, an easy digital signal processing. Once again the input is Vi and output is Vo
The timer output is high (1), and then receives the audio signal entering the trigger pin, alternating output low (0).
This shift from high to low state, we will be useful to create a rising edge that was used in the Flip-Flop.
Step 3: Flip-Flop
Picture of Flip-Flop
This step is important, here the pulse will remain activated to allow the lamp, until next slap sound
The applause generates a high state, but is very short (it takes what it takes slap). The flip-flop does is hold, the high state generated by slap.
Was used for this project a counter 7493, which has 4 Flip-flop's internal. You can also use Flip-flop's common as 7476 or 7473.
Step 4: Power Stage
Picture of Power Stage
At this stage, the pulse remained at the output of flip-flop is taken and applied power stage.
We use a fixed bias transistor as a switch to energize the relay coil. The diode is used to protect the transistor.
We can feed the relay with a voltage of 9-12 v. In this way we can light bulbs work with 12 volts. There are relays which can be fed with more voltaje.
Step 5: Complete Circuit
Picture of Complete Circuit
The last step would bind all, as shown in the picture. It can be seen that input Vi is the microphone input and output Vo is the lamp.
In the picture you can see that the relay is powered by 12v, but you can also use 9v battery, and thus can be connected to relay any device that is powered with 9 volts.
The other components are fed 5v. You can get this voltage by applying a "dimmer" a 9V battery.
amberrayh (author)2015-03-18
This is cool! Thanks for sharing. I hope we see more from you on Instructables in the future!
Jejeje I hope so. Thanks for commenting
turbiny (author)2015-03-21
are those chips stock/as sold or do i need to program them?
can there be a potentiometer between mic so it can be adjustable?
No, those chips are already scheduled. yeah, you can place the pot, although not the most effective way to adjust the mic.
About This Instructable
704views
19favorites
License:
More by cristian.d.angulo.9:Commutator Clapper On/Off Ligth
Add instructable to:
