For me Helmet lighting over bike lighting was the only way to go. When I can look at cars with my light, they know I am there. I have had zero close calls during my winter commutes due, I think to this choice of Helmet mounted lighting.
The following Instructable helped me achieve these goals. I needed lighter weight than most commercial offerings, Brighter spotlight capability(to aid with wildlife encounters etc.), Rear and Side!!! flashers, and selectable front flasher/direct beam capability. I did not need 37 modes of flashing, solid steel or aluminum enclosures, or a name brand system. Oh yeah, I wanted to use some batteries I already possessed to save some $$$. May I present my answer to seeing and being seen in the Harsh Alaskan urban and wilderness expanse...
Remove these ads by
Signing UpStep 1: Materials List
Lighting System Frame
3/4" x 36 x 1/8" Aluminum bar from Home depot ~ $8.00
6" x 6" x 1/8" Aluminum sheet from metal supply store ~ $2.00
http://www.ebay.com
1 2/PACK CLEAR TUBE TYPE REGISTRATION / PINK SLIP HOLDER $11.99
LED's, LED Constant Current Drivers, and Reflectors
http://www.luxeonstar.com
1 BuckPuck 1000mA DC LED Driver (With Leads) $15.99
2 Luxeon K2-TFFC LED - White Lambertian, 200 lm @ 1000mA $9.00 ea
1 BuckPuck 700mA DC LED Driver (With Leads) $15.99
4 Luxeon K2 LED - White Lambertian, 100 lm @ 700mA $6.21 ea
2 Luxeon K2 LED - Red-Orange Lambertian, 100 lm @ 700mA $4.63 ea
http://www.dealextreme.com
2 sku 04512 Star Connection Board for CREE LED Emiters (5-Pack) $2.00ea
1 sku 12436 25mm Plastic Reflector for LED Flashlights and Lighting Devices (5-Pack) $4.80
1 sku 04586 F3 33mm Smooth Plastic Optical Reflector (10-Pack) $7.81
Electronics
1 sku 04579 FUJIK Silicone Thermal Glue (50ml Grease-Like) $8.44
1 sku 05604 Clicky Switch for Flashlights (11.8mm 5-Pack) $1.80
http://www.ebay.com
1 Lot (10) Mini Toggle DPDT On-Off-On Switch 5A-125VAC $9.16
1 Lot (10) 555 Timers $4.00
Frigid North Electronics -- Anchorage, Alaska -- stuff for dimmer and 555 timer strobe
47uF 16V electrolytic capacitor $2.00
220uF 50V electrolytic capacitor $2.00
2 x 5 Kohm variable resistor $2.00ea
5Kohm 1/4 watt carbon resistor $2.00
270 ohm 1/4 watt carbon resistor (red purple brown) $0.50
Transistor from old mouse for dimmer circuit free
Total $140.16
I also used some miscellaneous screws that I already had, #4's, #6's, and Nylon #6's
References:
http://www.instructables.com/id/Small-Strobe-Light/
http://www.leddynamics.com/LuxDrive/datasheets/3021-BuckPuck.pdf
http://www.philipslumileds.com/pdfs/DS60.pdf
Visit Our Store »
Go Pro Today »
I'm a total electronics neophyte and just learning.
I'm going to make a front and rear light system for my bike so I'd like to modify your design for bike mounting
Where are your fuses and what sizes are they ?
What about cap's and resistors ? I saw on the flasher boards (you have one for the front andone for the rear, correct?) you have some electronics on them.
Did you use the 3023 buck drivers ?
Since some of my wiring runs will be a little longer, up to 30", should I put the cap's across the battery leads as Luxdrive recommends ?
How did you waterproof the lights ? All I saw was the front light clear plateTRV sealant. Does RTV sealant curing vapors effect the reflector or lens clarity during the curing process ?
Again, what a great lighting system and thank you for sharing !
